[fdo-trac] #317: SQLite: Valid extents not being returned.
FDO trac_fdo at osgeo.org
Sat Apr 19 01:08:11 EDT 2008
 Reporter:  jbirch           |         Owner:  traianstanev
     Type:  defect           |        Status:  new
 Priority:  major            |     Milestone:
Component:  SQLite Provider  |       Version:  3.3.1
 Severity:  3                |    Resolution:
 Keywords:                   |   External_id:
Comment (by traianstanev):
 So far I have been testing with Map3D, which uses the SpatialExtents()
 command to get the extents. I think MapGuide is still using the spatial
 context extents for this, which I have not implemented in this provider
 (due to the spatial_ref_sys table not containing the extents). It will be
 easy to add this to the spatial context reader, based on info in the
 spatial index, I think. It may incur the cost of constructing the spatial
 index, but it's not an operation that Studio does often, so it should be
 fine.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/317#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
