[fdo-trac] #325: PostGIS provider does not support Transaction correctly
FDO trac_fdo at osgeo.org
Mon Apr 21 13:56:10 EDT 2008
   Reporter:  mloskot           |       Owner:  mloskot
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:
  Component:  PostGIS Provider  |     Version:
   Severity:  3                 |    Keywords:  transactions
External_id:                    |
 From Bruno Scott (see #314):
 As soon as we hit the check-out or the check-in features
 command it crashes Autodesk Map 2008 (this append also
 with Map 2009) I found that if we turn off the transaction
 capability It works ok.
 Transactions have been
 [source:trunk/Providers/PostGIS/Src/Provider/ConnectionCapabilities.cpp at 3904#L91
 turned off] with fix submitted in (r3904)
Ticket URL: <http://trac.osgeo.org/fdo/ticket/325>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
