[fdo-trac] #326: FileToHdr-related fix for building 64 bit windows
core FDO projects.
trac_fdo at osgeo.org
Mon Apr 21 16:10:07 EDT 2008
#326: FileToHdr-related fix for building 64 bit windows core FDO projects.
Reporter: edzimmerman | Owner: edzimmerman
Type: defect | Status: new
Priority: major | Milestone:
Component: Build System | Version: 3.2.0
Severity: 3 | Keywords:
External_id: |
For now, the current FDO windows 64 bit porting effort assumes that most
developers will be building the x64 version of FDO on x86 win32 machines
using the x86_amd64 cross compiler. This means that when building the x64
platform configuration, the FDO.sln must build the win32 version of the
FileToHdr preprocessing utility called by the custom build steps in the
Common.vcproj and Fdo.vcproj. Furthermore, the x64 configurations of
Common.vcproj and Fdo.vcproj need to refer to the win32 version of the
FileToHdr utility in the relevant custom build steps.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/326>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
