[fdo-trac] #273: 64bit Linux build problem in ClientServices/prefix.cc
FDO trac_fdo at osgeo.org
Tue Mar 11 20:26:47 EDT 2008
 Reporter:  warmerdam    |         Owner:  warmerdam
     Type:  defect       |        Status:  new
 Priority:  minor        |     Milestone:
Component:  FDO API      |       Version:
 Severity:  4            |    Resolution:
 Keywords:  64bit linux  |   External_id:
Changes (by warmerdam):
 * cc: gregboone (added)
Comment:
 This problem is corrected in trunk in r3800 which uses unsigned long
 instead.  I think this is also 32bit safe.  It is not clear if this change
 should be migrated into the 3.3 branch or not.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/273#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
