[fdo-trac] #548: SQL Spatial 'DataStore' connection property is case sensitive
FDO trac_fdo at osgeo.org
Thu Aug 20 17:54:20 EDT 2009
   Reporter:  chriserickson  |       Owner:  gregboone
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.5.0
  Component:  FDO API        |     Version:  3.4.0
   Severity:  3              |    Keywords:
External_id:                 |
 When trying to connect to SQL Spatial 2008, I get an error:
 'FdoPtr::operator->': Cannot execute function due to invalid value for the
 input parameter(s) 'p'.
 After several hours of troubleshooting, I figured out that it is because I
 had the case wrong for my DataStore parameter.  The database name in SQL
 was 'Test' and I was trying to use 'test'.
 SQL Server is not case sensitive when you're using it and it should:
 a) allow the connection
 b) give some sort of description in the exception as far as which
 parameter it had trouble with.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/548>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
