[fdo-trac] #549: SQL Spatial - cannot read 'uniqueidentifier' fields
FDO trac_fdo at osgeo.org
Thu Aug 20 18:57:17 EDT 2009
   Reporter:  chriserickson  |       Owner:  gregboone
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.5.0
  Component:  FDO API        |     Version:  3.4.0
   Severity:  1              |    Keywords:
External_id:                 |
 With a SQL table that has a PK of ID UNIQUEIDENTIFIER (guid) it loads just
 fine, mapping the data type to be string(36).  However, when you try and
 select data, you get an error:
 OSGeo.FDO.Common.Exception: RDBMS: Incompatible column type  --->
 The table itself has no data in it.  Here is the script to create the
 table, as well as the code I'm using to select:
 CREATE TABLE [SqlCreated].[Geography](
         [ID] [uniqueidentifier] NULL,
         [Shape] [geography] NULL,
         [Description] [varchar](255) NULL
 ) ON [PRIMARY]
 Sample code:
             ISelect command =
 (ISelect)_database._connection.CreateCommand(CommandType.CommandType_Select);
             command.SetFeatureClassName(_class.QualifiedName);
             command.PropertyNames.Add(new Identifier("ID"));
             command.Prepare();
             IFeatureReader dataReader = command.Execute();
Ticket URL: <http://trac.osgeo.org/fdo/ticket/549>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
