[fdo-trac] #733: GenericRdbms: Premature property finalization on ApplySchema
FDO trac_fdo at osgeo.org
Thu Dec 2 11:03:20 EST 2010
 Reporter:  brentrobinson                                 |         Owner:  brentrobinson
     Type:  defect                                        |        Status:  closed
 Priority:  minor                                         |     Milestone:  3.6.0
Component:  GenericRdbms API                              |       Version:  3.6.0
 Severity:  3                                             |    Resolution:  fixed
 Keywords:  ApplySchema property modify schema overrides  |   External_id:
Changes (by brentrobinson):
  * status:  new => closed
  * version:  3.5.0 => 3.6.0
  * resolution:  => fixed
Comment:
 Revision: 5841
 Author: brentrobinson
 Date: 11:01:06 AM, Thursday, December 02, 2010
 Message:
 Ticket#733: added Get_ColumnName() function to
 FdoSmLpSimplePropertyDefinition. This function does not finalize the
 property but simply returns the property's column name. Call
 GetColumnName() in FdoSmLpGrdDataPropertyDefinition::Update() to prevent
 property finalizing before schema update complete.
 Modified :
 /trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/DataPropertyDefinition.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt
 Added :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides4_master.txt
 Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Lp/SimplePropertyDefinition.h
 Modified :
 /trunk/Utilities/SchemaMgr/Src/Sm/Lp/SimplePropertyDefinition.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/733#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
