[fdo-trac] #734: Problem reading negative Int64 values
FDO trac_fdo at osgeo.org
Fri Dec 3 06:42:19 EST 2010
   Reporter:  simonpel             |       Owner:  haris
       Type:  defect               |      Status:  new
   Priority:  major                |   Milestone:  3.5.0
  Component:  KingOracle Provider  |     Version:  3.5.0
   Severity:  3                    |    Keywords:
External_id:                       |
 If the Int64 value is negative (-1,-2 etc...) provider does not work.
 Strange behavior using the Fdo2Fdo tool and crashing Map3d 2011.
 Error reported when using the KingFdo provider:[[BR]]
 GetInt64 : ''Exception unrecognized, - objtype=void * __ptr64''
Ticket URL: <http://trac.osgeo.org/fdo/ticket/734>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
