[fdo-trac] #791: Memory leaks on FDO Schema and FdoCommon
FDO trac_fdo at osgeo.org
Wed Oct 5 11:23:15 EDT 2011
 Reporter:  brentrobinson  |         Owner:  brentrobinson
     Type:  defect         |        Status:  closed
 Priority:  minor          |     Milestone:  3.7.0
Component:  FDO API        |       Version:  3.7.0
 Severity:  3              |    Resolution:  fixed
 Keywords:  memory leak    |   External_id:
Changes (by brentrobinson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Revision: 6274
 Author: brentrobinson
 Date: 11:21:49 AM, Wednesday, October 05, 2011
 Message:
 Ticket#791: fixes a couple of memory leaks:
 FdoClassDefinition::SetBaseClass() - fixed refcount leak while looking for
 top base class.
  FdoCommonSchemaUtil::DeepCopyFdoAssociationPropertyDefinition() - Add
 source/destination property pair to context map earlier. This prevents
 copying this property twice, and adding it to the map twice, if it is
 revisited while deep copying the associated class. Adding the map a second
 time causes the original pair of properties to be leaked.
 Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassDefinition.cpp
 Modified : /trunk/Utilities/Common/Src/FdoCommonSchemaUtil.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/791#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
