[fdo-trac] #792: SQLServerSpatial: Invalid column error when inserting features
FDO trac_fdo at osgeo.org
Tue Oct 11 14:54:04 EDT 2011
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.7.0
  Component:  FDO API        |     Version:  3.7.0
   Severity:  2              |    Keywords:  SQL Server 2008 insert case sensitive
External_id:                 |
 If features are inserted into a SQL Server 2008 datastore with:
  * metadata (F_) tables
  * SQL Server instance with case sensitive collation
 then the insert fails with an "Invalid column 'ClassId'" message.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/792>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
