[fdo-trac] #792: SQLServerSpatial: Invalid column error when inserting features
FDO trac_fdo at osgeo.org
Tue Oct 11 14:59:42 EDT 2011
 Reporter:  brentrobinson                          |         Owner:  brentrobinson
     Type:  defect                                 |        Status:  closed
 Priority:  major                                  |     Milestone:  3.7.0
Component:  FDO API                                |       Version:  3.7.0
 Severity:  2                                      |    Resolution:  fixed
 Keywords:  SQL Server 2008 insert case sensitive  |   External_id:
Changes (by brentrobinson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Revision: 6275
 Author: brentrobinson
 Date: 2:57:13 PM, Tuesday, October 11, 2011
 Message:
 Ticket#792:  Replace the hard-coded system column names, in
 FdoRdbmsSimpleInsertCommand, with the names from their column objects.
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsSimpleInsertCommand.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/792#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
