[Fdo-trac] [fdo-trac] #845: FdoDateTime: Avoid returning invalid DateTime values
FDO trac_fdo at osgeo.org
Fri Aug 10 14:25:53 PDT 2012
   Reporter:  gregboone  |       Owner:  gregboone
       Type:  defect     |      Status:  new
   Priority:  minor      |   Milestone:  3.7.0
  Component:  FDO API    |     Version:  3.7.0
   Severity:  3          |    Keywords:
External_id:             |
 When using the FDO Expression Engine or when accessing FDO data stores
 using the FDO managed API, there exists a slight possibility that:
 1) a corrupted date (year == 0) may be returned from the expression engine
 2) an exception may be thrown when reading an unmanged FdoDateTime value
 and converting it to a System.DateTime value
 For the Expression Engine, exceptions are thrown for invalid
 months/days/etc... so an invalid year should also be handled in teh same
 manner. It is a long term goal that the EE become more forgiving whebn
 handling DateTime values, but that llarger change is not currently in
 scope for FDO 3.8.
 For the FDO Managed API, the date conversion typically happens when
 reading date values using the FdoIReader interface. Throwing exceptions
 when reading invalid datstore dates can be fatal to an application and in
 retropsect does not need to be treated as a hard failure.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/845>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
