[Fdo-trac] [fdo-trac] #845: FdoDateTime: Avoid returning invalid DateTime values
FDO trac_fdo at osgeo.org
Fri Aug 10 14:26:35 PDT 2012
   Reporter:  gregboone  |       Owner:  gregboone
       Type:  defect     |      Status:  assigned
   Priority:  minor      |   Milestone:  3.7.0
  Component:  FDO API    |     Version:  3.7.0
   Severity:  3          |    Keywords:
External_id:             |
Changes (by gregboone):
  * status:  new => assigned
Old description:
> When using the FDO Expression Engine or when accessing FDO data stores
> using the FDO managed API, there exists a slight possibility that:
> 1) a corrupted date (year == 0) may be returned from the expression
> engine
> 2) an exception may be thrown when reading an unmanged FdoDateTime value
> and converting it to a System.DateTime value
> For the Expression Engine, exceptions are thrown for invalid
> months/days/etc... so an invalid year should also be handled in teh same
> manner. It is a long term goal that the EE become more forgiving whebn
> handling DateTime values, but that llarger change is not currently in
> scope for FDO 3.8.
> For the FDO Managed API, the date conversion typically happens when
> reading date values using the FdoIReader interface. Throwing exceptions
> when reading invalid datstore dates can be fatal to an application and in
> retropsect does not need to be treated as a hard failure.
New description:
 1) a corrupted date (year == 0) may be returned from the expression engine
 2) an exception may be thrown when reading an unmanaged FdoDateTime value
 months/days/etc... so an invalid year should also be handled in the same
 manner. It is a long term goal that the EE become more forgiving when
 handling DateTime values, but that larger change is not currently in scope
 for FDO 3.8.
 when reading invalid data store dates can be fatal to an application and
 in retrospect does not need to be treated as a hard failure.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/845#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
