[fdo-users] SHP modifications issue
Dan Stoica dan.stoica at autodesk.com
Wed Jan 24 09:25:41 EST 2007
1) I'll drop this change, maybe today.
2) place a breakpoint in ShpConnection::~ShpConnection (void):
    // Do files compression (get rid of the deleted rows)
    CompressFileSets();
When your connection is released:
a) the desctuctor should be called
b) CompressFileSets() should find mGlobalRefCount == 1.
Cheers,
Dan.
-----Original Message-----
Sent: Wednesday, January 24, 2007 4:04 AM
To: Dan Stoica; Robert Fortin; Pierre Dalcourt; fdo-users at lists.osgeo.org
Subject: RE : RE: RE : RE: RE : RE: RE : RE: [fdo-users] SHP modifications issue
1) Ok I'll change this right after writing this mail
and I'll give it a go. Will you commit this correction
or do I have to keep in mind that I might have to
change this each time a new FDO version is released ?
2) still hoping :)
I think I really need to have a closer look at the FDO
internal, I can read C++ code but the thing is of
course that I don't know where to start :)
thank you again
--- Dan Stoica <dan.stoica at autodesk.com> a écrit :
> 1) have a look at:
> /providers/SHP/src/ShpRead/DataRow.cpp line #75:
>     else if (cVALID_RECORD_ID != ((char*)buffer)[0])
>         SetDeleted (true);
> I have no problem changing it to:
>     else if (cDELETED_RECORD_ID ==
> ((char*)buffer)[0])
>         SetDeleted (true);
> 2) Good luck :-)
> Dan.
___________________________________________________________________________
Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions !
Profitez des connaissances, des opinions et des expériences des internautes sur Yahoo! Questions/Réponses
http://fr.answers.yahoo.com
More information about the fdo-users mailing list
