[fdo-users] 3.3 GDAL provider does not work with MrSID plugin
Tue Nov 6 16:36:32 EST 2007
Tom Fukushima wrote:
> Hi Frank,
> I was trying out the FDO 3.3 GDAL provider for the next MGOS 2.0 release
> but found that when I tried to use the MrSID and ECW addons
> (http://home.gdal.org/dl/mapguide/) that I got the following error:
> “The application has failed to start because gdal13.dll was not found.
> Re-installing the application may fix this problem.”
> FDO 3.3 now uses gdal14.dll.  Could you make us some new MrSID and ECW
> plug-ins that are compatible with gdal14.dll.  The exact version in the
> dll is 1.4.0.0.
Tom,
Yes, I'll try and get produce these.  Feel free to poke me if you don't
hear anything with a week or so.
Note that a 1.4 compatible plugin should work with any GDAL 1.4.x release
(1.4.0 through 1.4.3 or the eventually 1.4.4).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the fdo-users mailing list
