[fdo-users] FDO for sde personal
Tony techswami at hotmail.com
Mon Aug 25 22:29:05 EDT 2008
yes SDE personal is not the SDE enterprise
SDE enterprise does have the instant running on 5151 port but SDE personal
does this connection using direct connect but its ESRI technology . i have
used OGR for personal geodatbase i know OGR can be used for personal
geodabase but dont know how
tony
Brad Nesom wrote:
> Tony,
> Did you have any luck? I am trying to do same and can't get the connection
> string. Perhaps because sde workgroup is not running a real sde process
> the
> arcsde provider doesn't use the same library.
> Any idea what port sde workgroup uses? 5151 is not doing the trick.
> Brad
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Tony
> Sent: Monday, August 25, 2008 12:39 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] FDO for sde personal
> Is there any FDO we can use for SDE personal ( SQL server express)
> http://n2.nabble.com/FDO-for-sde-personal-tp780698p780698.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/FDO-for-sde-personal-tp780698p783044.html
More information about the fdo-users mailing list
