[fdo-users] Trouble building FDO 3.3 in ubuntu 8
Daniel Monego MonegoDJ at cdm.com
Mon May 12 11:41:00 EDT 2008
I'm having trouble compiling the FDO package. When I run ./configure, this is
the output:
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for bison... no
checking for byacc... no
configure: error: cannot run /bin/bash ./config.sub
Looking into it, it seems like ./config.sub is a link to
/usr/share/libtool/config.sub, which doesn't exist on my computer. Is there
a required package that I'm missing?
View this message in context: http://www.nabble.com/Trouble-building-FDO-3.3-in-ubuntu-8-tp17189810p17189810.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
