Re[fdo-users] turn geometries
surrounded Rob.Sosnowski at itd.idaho.gov
Wed Sep 17 12:34:52 EDT 2008
Well, there is only one geometry returned.  So for example, if I step through
the program (using C#.net) the point shapefile I referred to returns the
following from the CreateGeometryFromFgf:
"Point(-116.925 44.058)" for the text.  This should be something like
"Point(-116.925 44.058, -116.xxx 44.xxx......)"
Gavin Cramer wrote:
> So... is the problem that ReadNext() only returns 'true' once, or that all
> geometries have the same value?
> Gavin
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of surrounded
> Sent: Wednesday, September 17, 2008 12:24 PM
> To: fdo-users at lists.osgeo.org
> Subject: RE: Re[fdo-users] turn geometries
> For instance, there are 44 counties within one shapefile - it only returns
> one.  There are 100+ points in another shapefile, it only returns one.
> NOTE: pcoords holds the geometry from GetGeometry - it is type byte[].  I
> acutally pass this byte[] into another function to convert it into
> geometry
> with CreateGeometryFromFgf.  That is why the code is not clear with the
> loop
> and the definition of pcoords.
> Thanks....
> Dan Stoica wrote:
>> I don't see any problem with that loop. Unless you get somehow an
>> exception and the loop beaks after the 1st retrieval. But you say you get
>> successfully one feature. So just to make sure: how many features are in
>> the SHP file?
>> Sent: Wednesday, September 17, 2008 11:45 AM
>> Subject: Re[fdo-users] turn geometries
>> Using shapefiles,  trying to return all geometries for all features
>> within
>> the shapefile.  Using the logic below, the geometry is returned for only
>> one
>> of the features within the shapefile.  How do I expand this logic to
>> return
>> all geometries.   Thanks....
>> OSGeo.FDO.Commands.Feature.ISelect sel =
>> (OSGeo.FDO.Commands.Feature.ISelect)connection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select);
>> sel.SetFeatureClassName(sSplit[1]);      //Where sSplit[1] is the name of
>> the shapefile
>> reader = sel.Execute();
>> while (reader.ReadNext())
>>     pCoords = reader.GetGeometry("Geometry");
>>     FgfGeometryFactory gFac = new FgfGeometryFactory();
>>     IGeometry geo = gFac.CreateGeometryFromFgf(pCoords);
>> View this message in context:
>> http://n2.nabble.com/Return-geometries-tp1095647p1095647.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://n2.nabble.com/Return-geometries-tp1095647p1095772.html
View this message in context: http://n2.nabble.com/Return-geometries-tp1095647p1095800.html
More information about the fdo-users mailing list
