[fdo-users] ODBC MS SQL Server error feature on check in after editing
kalmy kalman.albert at promax.ro
Thu Dec 3 13:56:36 EST 2009
I make a fdo odbc connection for MS SQL Server 2000 for a point feature
class. After edit the position on check in I got an error. the error is the
same for map2008/2009/2010.
Modifying the access mdb point feature class works .
1. I update Microsoft SQL MSDE 2000 to SP4 .
2. I have SP1 for Map 2008 (but also I test with Map2009 and the same)
3. The column name is uniq primary key, and Identify Yes
4. I connect via DNS
I attach the message box.
AutoDesk support recognize the error (they also reproduce the error on my
dataset) but after that no any information.
Thanks.
Kalmy
http://n2.nabble.com/file/n4108036/ODBC%2Berror.jpg ODBC+error.jpg
View this message in context: http://n2.nabble.com/ODBC-MS-SQL-Server-error-feature-on-check-in-after-editing-tp4108036p4108036.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
