[fdo-users] ODBC MS SQL Server error feature on check in after editing
Jackie Ng jumpinjackie at gmail.com
Thu Dec 10 20:02:24 EST 2009
Looking at the error at face value, it seems you have a string attribute
value that has overflowed (ie. It's length exceeds the maximum length for
that particular column)
- Jackie
kalmy wrote:
> I make a fdo odbc connection for MS SQL Server 2000 for a point feature
> class. After edit the position on check in I got an error. the error is
> the same for map2008/2009/2010.
> Modifying the access mdb point feature class works .
> 1. I update Microsoft SQL MSDE 2000 to SP4 .
> 2. I have SP1 for Map 2008 (but also I test with Map2009 and the same)
> 3. The column name is uniq primary key, and Identify Yes
> 4. I connect via DNS
> I attach the message box.
> AutoDesk support recognize the error (they also reproduce the error on my
> dataset) but after that no any information.
> Thanks.
> Kalmy
>  http://n2.nabble.com/file/n4108036/ODBC%2Berror.jpg ODBC+error.jpg
View this message in context: http://n2.nabble.com/ODBC-MS-SQL-Server-error-feature-on-check-in-after-editing-tp4108036p4148901.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
