[fdo-users] Trying to Deploy FDO to Web
surrounded Rob.Sosnowski at itd.idaho.gov
Tue Feb 17 12:10:19 EST 2009
Greg, the library paths are relative: For example,
.\ODBCProvider.dll
.\WMSProvider.dll
Greg Boone wrote:
> That DLL should be delay loaded and should not affect FDO from running.
> Have you looked at the contents of providers.xml located in the FDO bin
> directory? Are the paths to the provider files relative or absolute?
> Greg
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of surrounded
> Sent: Tuesday, February 17, 2009 11:46 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] Trying to Deploy FDO to Web
> Using DependencyWalker, I see that for OSGeo.FDO.dll and
> OSGeo.FDO.Common.dll, DWMAPI.DLL cannot be found.
> ANYONE RUN INTO THIS - RECOMMENDATION?
> surrounded wrote:
>> Hi Greg,
>> No, so if I download Depends.exe, how would I use it to determine the
>> missing module??
>> From: Greg Boone (via Nabble)
>> [mailto:ml-user+67529-964960874 at n2.nabble.com]
>> Sent: Tuesday, February 17, 2009 9:36 AM
>> To: Rob Sosnowski
>> Have you run depends.exe to try and determine which module cannot be
>> found?
>> From: fdo-users-bounces at ...
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=0>
>> [mailto:fdo-users-bounces at ...
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=1> ]
>> Sent: Tuesday, February 17, 2009 11:06 AM
>> To: fdo-users at ...
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=2>
>> Subject: [fdo-users] Trying to Deploy FDO to Web
>> Hello,
>> I'm using FDO within VS 2008 project (web service) and works fine when
>> run
>> as localhost on my PC.
>> I've moved the web service to a production server, copied the FDO bin,
>> lib,
>> and inc folders to the production server, and set the environment PATH
>> variable on the server to point to the FDO folders.
>> When I run the application I get the following error:
>> System.IO.FileNotFoundException: The specified module could not be
>> found.
>> (Exception from HRESULT: 0x8007007E)
>> ANY IDEAS ON WHAT IS CAUSING THIS?  HOW IS FDO SET UP TO RUN ON WEB
>> SERVER?
>> Thanks.....
>> View this message in context:
>> http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341612.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> fdo-users at ...
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=3>
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> fdo-users at ...
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=4>
>> This email is a reply to your post @
>> http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341773.html
>> You can reply by email or by visting the link above.
> http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341870.html
View this message in context: http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2342015.html
More information about the fdo-users mailing list
