[fdo-users] Trying to Deploy FDO to Web
surrounded Rob.Sosnowski at itd.idaho.gov
Tue Feb 17 15:06:48 EST 2009
Greg,
Using Windows XP, VS 2008, .Net 3.5, created web service using FDO.  Web
service works wonderful from VS 2008 debug, localhost, and by access
from Silverlight web application.
I've now tried to move the web service to a production server (Windows
Server 2003) by: copying over the webservice published code, copying
over the FDO bin, inc, and lib folders, changing the PATH environment
variable on the server to point to the FDO bin, inc, lib folders.
Nonetheless, I get the following error when I run the web service on the
server:
System.IO.FileNotFoundException: The specified module could not be
found. (Exception from HRESULT: 0x8007007E)
An unhandled exception was generated during the execution of the current
web request. Information regarding the origin and location of the
exception can be identified using the exception stack trace below.
I've tried FDO versions 3.3.1, 3.3.2, 3.3.4; all have resulting in same
error.  DependencyWalker just states that I'm missing DWMAPI.dll, which
you pointed out should not matter.
WHAT AM I MISSING....
[mailto:ml-user+67529-964960874 at n2.nabble.com]
Sent: Tuesday, February 17, 2009 10:04 AM
To: Rob Sosnowski
Subject: RE: [fdo-users] Trying to Deploy FDO to Web
That DLL should be delay loaded and should not affect FDO from running.
Have you looked at the contents of providers.xml located in the FDO bin
directory? Are the paths to the provider files relative or absolute?
Greg
-----Original Message-----
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=0>
[mailto:fdo-users-bounces at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=1> ]
On Behalf Of surrounded
Sent: Tuesday, February 17, 2009 11:46 AM
To: fdo-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=2>
Using DependencyWalker, I see that for OSGeo.FDO.dll and
OSGeo.FDO.Common.dll, DWMAPI.DLL cannot be found.
ANYONE RUN INTO THIS - RECOMMENDATION?
surrounded wrote:
> Hi Greg,
> No, so if I download Depends.exe, how would I use it to determine the
> missing module??
> From: Greg Boone (via Nabble)
> [mailto:ml-user+67529-964960874 at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=3> ]
> Sent: Tuesday, February 17, 2009 9:36 AM
> To: Rob Sosnowski
> Have you run depends.exe to try and determine which module cannot be
> found?
> From: fdo-users-bounces at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=0>
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=1> ]
> Sent: Tuesday, February 17, 2009 11:06 AM
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=2>
> Subject: [fdo-users] Trying to Deploy FDO to Web
> Hello,
> I'm using FDO within VS 2008 project (web service) and works fine when
> run
> as localhost on my PC.
> I've moved the web service to a production server, copied the FDO bin,
> lib,
> and inc folders to the production server, and set the environment PATH
> variable on the server to point to the FDO folders.
> When I run the application I get the following error:
> found.
> ANY IDEAS ON WHAT IS CAUSING THIS?  HOW IS FDO SET UP TO RUN ON WEB
> SERVER?
> Thanks.....
http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341612.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=3>
> http://lists.osgeo.org/mailman/listinfo/fdo-users
> fdo-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=4>
> ________________________________
> This email is a reply to your post @
http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341773.html
> You can reply by email or by visting the link above.
http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341870.html
fdo-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=4>
fdo-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=5>
http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341971.html
View this message in context: http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2343000.html
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090217/0aef38c2/attachment-0001.html
More information about the fdo-users mailing list
