[fdo-users] finally
Jason Birch Jason.Birch at nanaimo.ca
Wed May 20 12:25:14 EDT 2009
Just bringing MapGuide-Internals and FDO-Internals into this thread, in case the MapGuide devs aren't following the users list closely.
Jason
-----Original Message-----
Sent: Wednesday, May 20, 2009 12:14 AM
Subject: RE: [fdo-users] finally
It is not DescribeSchema which is problem in this case. MG is taking
class from reader and is changing parent schema of it.
Multithreading is making this problem with reader to show up. Problem
you had in sqlite is solved same way as it was solved in King.Oracle
with deepcopy of schema. But that was another issue.
Of course, performance is reason to not use xml.
More information about the fdo-users mailing list
