[fdo-users] finally
doggybs james.slater at keynetix.com
Tue May 26 04:45:38 EDT 2009
This is a real problem to us, as we are hoping to go live with our new system
in a few weeks. I don't suppose there are any plans to release a patched
postgis FDO with the work around Haris has suggested until mapguide is
fixed?
Many Thanks
James
Jason Birch wrote:
> Just bringing MapGuide-Internals and FDO-Internals into this thread, in
> case the MapGuide devs aren't following the users list closely.
> Jason
> -----Original Message-----
> From: Haris Kurtagic
> Sent: Wednesday, May 20, 2009 12:14 AM
> Subject: RE: [fdo-users] finally
> It is not DescribeSchema which is problem in this case. MG is taking
> class from reader and is changing parent schema of it.
> Multithreading is making this problem with reader to show up. Problem
> you had in sqlite is solved same way as it was solved in King.Oracle
> with deepcopy of schema. But that was another issue.
> Of course, performance is reason to not use xml.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/finally-tp2939043p2973524.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
