[fdo-users] Impossible to select an object on map mapguide
Dejan Gregor dejan.gregor at GMAIL.COM
Tue Jan 12 06:28:14 EST 2010
Haris,
I followed some discussions on Oracle Forums on the topic on setting a PK on
a non-materialized Oracle View
http://forums.oracle.com/forums/search.jspa?threadID=&q=oracle+view+spatial+primary+key&objID=c84&dateRange=all&userID=&numResults=15
I have applied the Autodesk MGE Oracle provider that came with the default
installation. I will also test the KingFdoClass metadata (based on its
functional spec. at http://www.sl-king.com/fdooracle/KingFdoClass.htm it
offers many solutions to problems I am dealing with) .
The KingFdoClass metadata is marked as 'beta', when it will become 'in
production'? Also, do I need to create the table for every schema and/or
table?
Thanks for the hint!
Dejan
Dejan Gregor, MSc
GISc Researcher and Consultant
http://www.linkedin.com/in/dgregor
View this message in context: http://n2.nabble.com/Impossible-to-select-an-object-on-map-mapguide-tp3806579p4291018.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
