[fdo-users] ArcSDE personal connect
Brad Nesom kidsmake6 at msn.com
Mon May 24 10:50:40 EDT 2010
I have tried both.
On Sun, May 23, 2010 at 10:58 PM, Jack Lee <jack.lee at sympatico.ca> wrote:
> Hi Brad,
> You should use the ArcSDE provider.
> For the instance name, did you use sde:myserver\sqlexpress or
> sde:sqlserver:myserver\sqlexpress?
> On 5/21/2010 9:26 AM, Brad Nesom wrote:
>   I have been trying to make an autocad map (2010, 2011) connection to
> sql2008 express with an arcsde 9.3.1 personal gdb. I get several reactions
> depending on which connection and the values I use. I tried going through
> autodesk support to get a resolution. I got the following response from
> them. I have seen some responses on this forum expressing that the
> connection is possible. Any help would be appreciated.
> Brad
> My connection parameters...
> sql server spatial
> service name:              sde:sqlsserver:myserver\sqlexpress
> response:                    credentials are not valid or provider is
> unable to establish a connection.
> ArcSDE connection
> server name:                myserver\sqlexpress
> instance name:            sde:myserver\sqlexpress
> response:                   no error on credentials but the data store not
> populated
> the sde:sqlserver:myserver\SQLEXPRESS syntax works in FME and returns the
> geometry correctly
> Autodesk Response ...
> Here's the official word from the product manager:
> This is not a supported configuration. Not tested. I suspect the "local
> connect" string is not understood by our provider.  But even if Map 3D did
> connect, you wouldn’t be able to "create a datastore". FDO Provider for
> ArcSDE doesn’t allow creation of data store from Map 3D. you can only
> connect and edit existing ArcSDE Data Stores.
> fdo-users mailing listfdo-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100524/0e5ab96b/attachment.html
More information about the fdo-users mailing list
