[fdo-users] Problem with FDO King Oracle Provider - unable to load library
dblackbeer dblackbeer at gmail.com
Thu Aug 18 20:37:35 EDT 2011
On 18 August 2011 19:09, Jan Małysiak <j.malysiak at hotmail.com> wrote:
> Hi all,
> I am not able to connect to Oracle database using King Oracle Provider. I'm
> trying to establish the connection in MapGuide Maestro, but I receive a long
> message of an error, where I think the most important part is
> "CLNT_8_UNABLE_TO_LOAD_LIBRARY". The same appears in the error log, and the
> same in mapagent when I try to get capabilities for King Oracle Provider.
> I've already found several descriptions of similar problems posted by other
> users, but unfortunately none of them solved my problem. I have added the
> provider entry in providers.xml file, downloaded Oracle Instant Client,
> added its path to LD_LIBRARY_PATH, checked dependencies for
> libKingOracleProvider.so, copied required Oracle libraries to FDO/lib
> directory, now when I run ldd command for the libKingOracleProvider.so it
> says that all required libraries are found, nevertheless the error
> establishing new connection still occurs.
> I use:
> MapGuide Open Source 2.1.0
> FDO 3.4.0
> MapGuide Maestro 2.1.4
> Ubuntu 10.10
> Oracle Instant Client 10.2.0.4
> I'm not sure of the version of King Oracle Provider as I downloaded it in an
> archive together with other FDO providers.
> I would be very thankful for any help.
> Best regards,
> Jan Małysiak
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
King Oracle Provider it doesn't supported under linux.
dblackbeer
More information about the fdo-users mailing list
