[fdo-users] Problem with FDO King Oracle Provider - unable to load library
Jan Małysiak j.malysiak at hotmail.com
Thu Aug 18 18:09:31 EDT 2011
Hi all,
I am not able to connect to Oracle database using King Oracle Provider.
I'm trying to establish the connection in MapGuide Maestro, but I
receive a long message of an error, where I think the most important
part is "CLNT_8_UNABLE_TO_LOAD_LIBRARY". The same appears in the error
log, and the same in mapagent when I try to get capabilities for King
Oracle Provider.
I've already found several descriptions of similar problems posted by
other users, but unfortunately none of them solved my problem. I have
added the provider entry in providers.xml file, downloaded Oracle
Instant Client, added its path to LD_LIBRARY_PATH, checked dependencies
for libKingOracleProvider.so, copied required Oracle libraries to
FDO/lib directory, now when I run ldd command for the
libKingOracleProvider.so it says that all required libraries are found,
nevertheless the error establishing new connection still occurs.
I use:
MapGuide Open Source 2.1.0
FDO 3.4.0
MapGuide Maestro 2.1.4
Ubuntu 10.10
Oracle Instant Client 10.2.0.4
I'm not sure of the version of King Oracle Provider as I downloaded it
in an archive together with other FDO providers.
I would be very thankful for any help.
Best regards,
Jan Małysiak
More information about the fdo-users mailing list
