[fdo-users] Re: WFS memory usage
Greg Boone greg.boone at autodesk.com
Tue Aug 23 18:13:48 EDT 2011
Yes, send it to fdo-internals. I can ask one of XML knowledgeable developers to review it. If it looks OK we can apply it to the trunk. The option of a patch against a previous release is also an option.
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Robin Newton
Sent: Tuesday, August 23, 2011 5:16 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Re: WFS memory usage
Robin Newton wrote:
> I guess I should have also asked: (c) Is FdoXmlFeatureReaderImpl
> hanging on to all these features likely to be be a major factor in
> memory use? To which my current answer would have to be "no".
That was a bit hasty. It turned out my replication example was falling foul of the stack issue before it had a chance to exhaust heap space. With the stack issue dealt with a I get a memory exhaustion problem that can be fixed by tweaking the code to FdoXmlFeatureReaderImpl::ReadNext so that it releases features which aren't needed any more.
I'm not quite sure what I'm going to do with this, but if I wanted to submit a patch for consideration for the next release of FDO, what's the etiquette?
Is this something I should ask about on the 'internals' list?
Thanks,
Robin
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-memory-usage-tp6688451p6715370.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
