[FOSS-GPS] Position modes in RTKPOST
António Pestana afsm.pestana at gmail.com
Tue Nov 1 09:38:31 EDT 2011
Dear Mr. Takasu
Once again I must thank you for your patience and kindness.
Regarding your answer to my questions:
1. Yes, you are right: I mean "least square".
2. By EKF are you referring to "extended Kalman filter"? I suppose that
"extended Kalman filter" is KF applied to non-linear mathematical models.
Am I right?
Best regards
Antonio
>  I think that a) and b) are not suitable to RTK positioning because of the
>> ill-conditioning of the design matrix (very short observation time spans,
>> frequently one solution per epoch). I'm I right?
> Not right.
> KF can handle only one epoch observations
> (but usually has no meaning). LS or KF is just
> a design selection.
 1. RTKPOST "static" is like c.1)?
>> 2. RTKPOST "kinematic" is like c.2) or c.3)?
>> 3. And RTKPOST "single"? Is it LMS/WLMS?
> In "single", RTKPOST uses weighted LS.
> In other modes, RTKPOST uses EKF.
> regards,
> Tomoji TAKASU
> From: "António Pestana" <afsm.pestana at gmail.com>
> Sent: Tuesday, November 01, 2011 6:48 AM
> To: "Open Source GPS-related discussion and support" <
> foss-gps at lists.osgeo.org>
> Subject: Re: [FOSS-GPS] Position modes in RTKPOST
>  Dear Mr. Takasu an other list members:
>> I am aware (not really aware, I've just heard off...) of the following
>> solutions to the positioning problem we are dealing with (GNSS
>> positioning):
>> a) Least mean square (LMS)
>> b) Weighted least mean square (WLMS)
>> c) Kalman filter
>> c.1) static positioning: coordinates of the receiver are constants and the
>> estimated clock offset of the receiver is white noise with zero mean
>> c.2) kinematic positioning for high receiver velocity: coordinates and
>> clock offset are modelled as zero mean white noise
>> c.3) kinematic positioning for low velocity: the coordinates are modelled
>> as a random walk
>> If I'm right then it follows that in RTK we are using some sort of "Kalman
>> filter" type solutions. And if we are using "Kalman filters" type
>> solutions
>> then the following questions arise:
>> Regards
>> Antonio
>> 2011/10/28 Tomoji TAKASU <ttaka at yk.rim.or.jp>
>>  Dear Antonio
>>>  Can anyone explain give me a brief explanation regarding the differences
>>>> between the position modes options in RTKPOST? I am especially
>>>> interested
>>>> in
>>>> the following modes: Single, Kinematic, Static, Moving-base and Fixed.
>>> I think they are generally common terminologies
>>> among GNSS positioning area except for "Fixed".
>>> So see the manual and search by Google.
>>> "Fixed" is special in RTKLIB. In the mode, the user
>>> position is fixed to a priori values specified by user
>>> options and other parameters like ionosphere,
>>> troposphere are estimated. It is also used for the
>>> analysis of measurement noise and multi-path with
>>> residuals.
>>> regards,
>>> Tomoji TAKASU
>>> Sent: Saturday, October 29, 2011 3:34 AM
>>> Subject: [FOSS-GPS] Position modes in RTKPOST
>>>> interested
>>>> in
>>>> Regards
>>>> Antonio
>>>  ______________________________****_________________
>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>>> Visit http://lists.osgeo.org/****mailman/listinfo/foss-gps<http://lists.osgeo.org/**mailman/listinfo/foss-gps>
>>>> <http**://lists.osgeo.org/mailman/**listinfo/foss-gps<http://lists.osgeo.org/mailman/listinfo/foss-gps>>to
>>>> manage your subscription
>>>> For more information, check http://wiki.osgeo.org/wiki/****FOSS-GPS<http://wiki.osgeo.org/wiki/**FOSS-GPS>
>>>> <http://wiki.osgeo.**org/wiki/FOSS-GPS<http://wiki.osgeo.org/wiki/FOSS-GPS>
>  ______________________________**_________________
>> Visit http://lists.osgeo.org/**mailman/listinfo/foss-gps<http://lists.osgeo.org/mailman/listinfo/foss-gps>to manage your subscription
>> For more information, check http://wiki.osgeo.org/wiki/**FOSS-GPS<http://wiki.osgeo.org/wiki/FOSS-GPS>
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20111101/6c4cf870/attachment.html
More information about the FOSS-GPS mailing list
