[FOSS-GPS] RTKLIB - rtkrcv in linux.
julio menezes yjmenezes at yahoo.com.br
Sat Jun 2 17:13:16 PDT 2012
Hi Jefferson
--- Em sáb, 2/6/12, Jefferson Luiz Ferreira <jeffersonlferreira at yahoo.com.br> escreveu:
De: Jefferson Luiz Ferreira <jeffersonlferreira at yahoo.com.br>
Assunto: [FOSS-GPS] RTKLIB - rtkrcv in linux.
Para: "foss-gps at lists.osgeo.org" <foss-gps at lists.osgeo.org>
Data: Sábado, 2 de Junho de 2012, 13:20
hi,
I'm running rtkrcv in linux, but I found some troubles.
I can't run rtkrcv as a command line, without enter the command prompt.
Someone knows how call rtkrcv without the command prompt?
When I call like this:
./rtkrcv -s -o config_file.conf
the command prompt open and stay opened until I do a shutdown.
I want to execute the rtkrcv from a script without any message.
I wrote an script just now, the problem is how to stop the daemon, may be thru  a telnet console.
#!/bin/bash
#$ GPL2 by yjmenezes at gmail.com ver 1.0 at 2012-06-02 $
# This is just one idea.
if [ $# -lt 5 ]; then
    clear 1>&2
    echo `basename $0` "
 rtkrcv [-s][-p port|-d dev][-o file][-t level]
OPTIONS
 -s start RTK server on program startup
 -p port port number for telnet console
 -m port port number for monitor stream
 -d dev terminal device for console
 -o file configuration file
 -r level output solution status file (0:off,1:states,2:residuals)
 -t level debug trace level (0:off,1-5:on)
" 1>&2
    echo `basename $0` "-s -d /dev/ttyACM0 -o rtkrcv.conf " 1>&2
    echo "ps  -ef | grep  ^rtkit  to see it running and/or to send USR2 signal to the process; kill -USR2 [PID]" 1>&2
    exit 1
fi
PROG=/usr/local/bin/gps/rtkrcv
ARGS=`echo $*` 1>&2
echo "args:" $ARGS 1>&2
# finaly
$PROG $ARGS
exit 0
I hope it helps.
Wich receiver are you working with ?
regards,
julio menezes
gpl2.com.br
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20120602/46c27ea6/attachment.html>
More information about the FOSS-GPS mailing list
