[FOSS-GPS] Difference in Solution vs Status RTKLIB
bjorn.spockeli bjorn.spockeli at gmail.com
Mon Feb 16 02:24:07 PST 2015
Im using rtkrcv in single mode and when comparing the output solution
against the status im seeing huge differences. Showing the status in rtkrcv
shows the position being updated at 1 Hz and it is fairly accurate. However
when I look at the solution in rtkrcv the position is way off and it is
almost ot updating at all.
Why is the output solution so much worse than the status?
Bjørn
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Difference-in-Solution-vs-Status-RTKLIB-tp7573149.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
