[FOSS-GPS] RTKLIB CMR PROTOCOL
Dan Cook danco at cox.net
Sun Jan 25 07:42:37 PST 2015
> But support or not support CMR+?
> i have try ntrip server CMR+ but not show satellite bars and not FIX
position.
That's correct. RTKLIB does not contain code to process CMR, CMR+ or CMRX.
Try looking for specifications for each of those, then read those
specifications and try implementing actual code to handle them within the
RTCM oriented framework in RTKLIB. Good luck. It would be easier to switch
to an RTCM3 mount point on your NTRIP caster.
More information about the FOSS-GPS mailing list
