[FOSS-GPS] RTKLIB CMR PROTOCOL
David Kelley DavidKelley at iTSware.net
Sun Jan 25 17:14:25 PST 2015
/cocute
I suggest you look on the NTRIP server you use to find an RTCM rev 2.x
mount point to use.  If you need CRM/CRM+ then your device can probably
consume Rev 2.1/2/3 messages and may not work with "modern" RTCM rev 3.x
type messages.   RTKLIB can do either format, but of course you have to
tell it which one.  As rule in the US market, CMR is mostly used by the
Agriculture market segment, and the latter variants have not been widely
adopted outside of Trimble (its inventor).  CMR was intended simply to
reduce message bandwidth, which it does moderately well. ///The newer
stuff is also covered by patents. /
One final observation regarding RTKNAVI: the green LED means it is
connected, the light green blink means it parsed a messages, but it does
not mean that the message was successfully decoded or used in the
navigator filter. Setting the Debug trace to a higher level is your best
bet here  (Options->Tab3 "Output" -> Debug Trace)
On 1/25/2015 7:42 AM, Dan Cook wrote:
>> But support or not support CMR+?
>> i have try ntrip server CMR+ but not show satellite bars and not FIX
> position.
> That's correct. RTKLIB does not contain code to process CMR, CMR+ or CMRX.
> Try looking for specifications for each of those, then read those
> specifications and try implementing actual code to handle them within the
> RTCM oriented framework in RTKLIB. Good luck. It would be easier to switch
> to an RTCM3 mount point on your NTRIP caster.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
Regards,
David Kelley
ITS Programs Manager
SubCarrier Systems Corp. (SCSC)
626-485-7528 (Cell)     626-513-7715 (Office)
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150125/63479b8a/attachment.html>
More information about the FOSS-GPS mailing list
