[FOSS-GPS] Can rtkrcv create a pseudo-terminal?
arwooldridge arwooldridge at googlemail.com
Fri Nov 6 09:57:28 PST 2015
Have you looked at strsvr or its console version str2str ?
This may give you the function you need.
Regards
Anthony
On 06/11/2015 16:56, Fred Labrosse wrote:
> All,
> SO far I have used socat to create a pair of linked pseudo terminals, one
> used by rtkrcv to output the solution into, the other to be used by my
> favourite NMEA consumers as a "normal" serial device.
> For a number of reasons I would like to move away from socat, so I was
> reading about /dev/ptmx.  And this made me think that actually this is
> something that rtkrcv should handle, as the holder of the master of the
> created slave pseudo terminal.
> Any one knows if rtkrcv can do that?  If not, if I modify rtkrcv so that it
> does it, would the authors be interested in the code to include that in the
> package?  I can't do it for windows though.
> Cheers,
> Fred
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
