[FOSS-GPS] ublox NL-6002U
Mike McLoughlin
mike.mcloughlin at rockmate.com
Wed Mar 2 05:31:56 PST 2016
Hi Anton,
I am trying to get decimetre and better accuracy.
I have 2 of UBLOX NEO-6P. I have windows computers which record NMEA data as well as RINEX data but I do not seem to be able to get an accurate fix when I run the data through RTKlib. I am not using RTKlib to record the data on the computers. I am using RTKlib to do the post processing.
Regards,
MacSam
-----Original Message-----
From: FOSS-GPS [mailto:foss-gps-bounces at lists.osgeo.org] On Behalf Of agstrydom at gmail.com
Sent: 02 March 2016 08:24
To: Open Source GPS-related discussion and support <foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] ublox NL-6002U
Hi Guys
If you could be more specific with what you would like to do etc and what you are battling with give me a shout and I will try and help
Regards
Anton
Sent via my BlackBerry
Sender: "FOSS-GPS" <foss-gps-bounces at lists.osgeo.org>Date: Wed, 02 Mar 2016 09:00:25
To: Open Source GPS-related discussion and support<foss-gps at lists.osgeo.org>
Reply-To: Open Source GPS-related discussion and support <foss-gps at lists.osgeo.org>
> Anyone any experience of using u-blox NL-6002U receiver with RTKlib?
> I am trying to use one as a base, and the another as a rover and not
> having much success.
> MacSam
Same question here. I am trying to use a Ublox-M8T without success. I am running Debian GNU/Linux and don't have access to (and will not want to use) Windows. RTKlib documentation for Windows is very precise, but is not as complete on the Linux executable side, especially for GPS noobs like me.
If you are running Windows, I would suggest that you collect information on your base station and then calculate the accurate position of the base station using RTKlib to go down to 2cm precision.
You must have clear sky.
Good luck and keep us informed.
Kind regards
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
