[FOSS-GPS] ublox NL-6002U
agstrydom at gmail.com agstrydom at gmail.com
Wed Mar 2 00:24:06 PST 2016
Hi Guys
If you could be more specific with what you would like to do etc and what you are battling with give me a shout and I will try and help
Regards
Anton
Sent via my BlackBerry
-----Original Message-----
Sender: "FOSS-GPS" <foss-gps-bounces at lists.osgeo.org>Date: Wed, 02 Mar 2016 09:00:25
To: Open Source GPS-related discussion and support<foss-gps at lists.osgeo.org>
Reply-To: Open Source GPS-related discussion and support
Subject: Re: [FOSS-GPS] ublox NL-6002U
> Anyone any experience of using u-blox NL-6002U receiver with RTKlib?
> I am trying to use one as a base, and the another as a rover and not
> having
> much success.
> MacSam
Same question here. I am trying to use a Ublox-M8T without success. I
am running Debian GNU/Linux and don't have access to (and will not want
to use) Windows. RTKlib documentation for Windows is very precise, but
is not as complete on the Linux executable side, especially for GPS
noobs like me.
If you are running Windows, I would suggest that you collect
information on your base station and then calculate the accurate
position of the base station using RTKlib to go down to 2cm precision.
You must have clear sky.
Good luck and keep us informed.
Kind regards
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
