[FOSS-GPS] Foxtrotgps shows sometimes openstreetmap.org maps on screen
David Bannon dbannon at internode.on.net
Fri Nov 17 01:09:40 PST 2023
Hmm, Fred, I cannot find my gps mouse so cannot run gpsd. But I just
installed gpsd and seems I was wrong, no group gpsd. But there is a gpsd
user. Now, thats the user who should be launching gpsd, not root. If you
have a gpsd plugged in, see if you can see that process -
ps aux | grep gpsd
and look to see who the user is.
Might be worth checking /run/gpsd, that is gpsd's 'home' directory and
where it will drop state files. If there are files in there, who owns them ?
Seems that gpsd talks over d-bus or some shared memory model, D-Bus is
pretty reliable but the shared memory model may be very user sensitive.
Honestly, IDK.
David
On 17/11/23 06:33, Fred Mobach via FOSS-GPS wrote:
> On Thursday, November 16, 2023 11:41:23 AM CET David Bannon via FOSS-GPS
> wrote:
>> Fred, my opinion may not be very valuable as I have not used Foxtrot for
>> some time. But, two suggestions :
>> * Firstly, by running a program like this as root, you may have caused a
>> whole lot of files in fred's space to be owned by root. When you then
>> run as fred, you find that fred cannot write to those files. Its just
>> about never a good idea to run a user space GUI app as root.
> Running as root was just to test if the problem was also there, but it wasn't.
> Please note that the problem arose when foxtrotgps had always been run under
> the user fred. Additionally I've checked alle subdirectories under the user
> fred but all files are owned by the user fred.
>> * Second, from memory, gpsd runs as the user gpsd. For fred to be able
>> to read gpsd's data, fred probably needs to be in the gpsd group. Can
>> you check that please, maybe look to see if there is a gpsd user and
>> group, if so, is fred also a member of the gpsd group ? They these
>> commands as user fred -
>> $> cat /etc/group | gpsd <enter>
> The gpsd doesn't appear in the file /etc/groups.
> Nevertheless thanks for your help, I appreciate that.
> Fred Mobach
>> On 15/11/23 05:01, Fred Mobach via FOSS-GPS wrote:
>>> Hello,
>>> Since years I'm using foxtrotgps to show openstreetmap.org maps with my
>>> added POI's on screen to have an overview of those POI's in a centain
>>> environment.
>>> All of a sudden moment the maps were not shown when running in a common
>>> user environment while the same programm running under root shown the
>>> maps in the normal way. What this problem initiated is unknown to me.
>>> To shown the problem the attachments shows the diffenrences:
>>> - left the screen running under root,
>>> - middle the configuration panel,
>>> - right the screen running under user fred.
>>> Note the error message No GPSD found: that missing device get the maps
>>> again unde user fred.
>>> So my question is how to get those maps under user fred displayed again.
>>> Regards,
>>> Fred
>>> This message is sent to youfromFOSS-GPS at lists.osgeo.org   mailing list.
>>> Visithttps://lists.osgeo.org/mailman/listinfo/foss-gps  to manage your
>>> subscription For more information,
>>> checkhttp://wiki.osgeo.org/wiki/FOSS-GPS
> This message is sent to you fromFOSS-GPS at lists.osgeo.org  mailing list.
> Visithttps://lists.osgeo.org/mailman/listinfo/foss-gps  to manage your subscription
> For more information, checkhttp://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20231117/d5689ccf/attachment.htm>
More information about the FOSS-GPS mailing list
