[FOSS-GPS] Foxtrotgps shows sometimes openstreetmap.org maps on screen
Fred Mobach fred at mobach.nl
Thu Nov 16 11:33:22 PST 2023
On Thursday, November 16, 2023 11:41:23 AM CET David Bannon via FOSS-GPS
wrote:
> Fred, my opinion may not be very valuable as I have not used Foxtrot for
> some time. But, two suggestions :
> * Firstly, by running a program like this as root, you may have caused a
> whole lot of files in fred's space to be owned by root. When you then
> run as fred, you find that fred cannot write to those files. Its just
> about never a good idea to run a user space GUI app as root.
Running as root was just to test if the problem was also there, but it wasn't.
Please note that the problem arose when foxtrotgps had always been run under
the user fred. Additionally I've checked alle subdirectories under the user
fred but all files are owned by the user fred.
> * Second, from memory, gpsd runs as the user gpsd. For fred to be able
> to read gpsd's data, fred probably needs to be in the gpsd group. Can
> you check that please, maybe look to see if there is a gpsd user and
> group, if so, is fred also a member of the gpsd group ? They these
> commands as user fred -
> $> cat /etc/group | gpsd <enter>
The gpsd doesn't appear in the file /etc/groups.
Nevertheless thanks for your help, I appreciate that.
Fred Mobach
> On 15/11/23 05:01, Fred Mobach via FOSS-GPS wrote:
> > Hello,
> > Since years I'm using foxtrotgps to show openstreetmap.org maps with my
> > added POI's on screen to have an overview of those POI's in a centain
> > environment.
> > All of a sudden moment the maps were not shown when running in a common
> > user environment while the same programm running under root shown the
> > maps in the normal way. What this problem initiated is unknown to me.
> > To shown the problem the attachments shows the diffenrences:
> > - left the screen running under root,
> > - middle the configuration panel,
> > - right the screen running under user fred.
> > Note the error message No GPSD found: that missing device get the maps
> > again unde user fred.
> > So my question is how to get those maps under user fred displayed again.
> > Regards,
> > Fred
> > This message is sent to you fromFOSS-GPS at lists.osgeo.org  mailing list.
> > Visithttps://lists.osgeo.org/mailman/listinfo/foss-gps  to manage your
> > subscription For more information,
> > checkhttp://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
