[FOSS4G-UK] [External] Re: Logo
Barry Rowlingson b.rowlingson at lancaster.ac.uk
Wed Jun 14 02:24:02 PDT 2023
I've added an animated gif version as well (during parts of a department
meeting this morning...).
Of course static PNG versions can be generated from the SVG - maybe the
local groups will want to use images that highlight their location?
To make the animation all I did was use Firefox' dev tools to trigger the
"hover" style for each location and then use a screen-grab browser add-on,
then use ImageMagick to make a gif.
Barry
On Tue, Jun 13, 2023 at 1:10 PM Barry Rowlingson <
b.rowlingson at lancaster.ac.uk> wrote:
> A day or so faffing with R and text on curves and SVG and CSS and...
> Here's a logo:
>  https://b-rowlingson.gitlab.io/foss4guk2023/
>  thoughts etc?
> Barry
> On Fri, Jun 9, 2023 at 8:17 AM Rowlingson, Barry <
>> On Wed, Jun 7, 2023 at 4:35 PM Nick Bearman <
>> nick at geospatialtrainingsolutions.co.uk> wrote:
>>> I'm not 100% sure about Ireland having a different colour and with the
>>> dots being on the diagonal rather than on the straight (up and down) - one
>>> or the other would be fine, I think both is a bit over kill. What do you
>>> think?
>> Yeah, I think as an exercise I tried both and left them both in! Just
>> colour is probably better.
>>> Also, something weird is happening between NI and Scotland - not sure
>>> what the three dots are doing there.
>> The dots are produced by QGIS' point-pattern fill style, so I'll ask it!
>> I suspect there's some islands or something... I did a lot of adjustment of
>> pattern fill offsets to try and get something that resembled last year's
>> logo in terms of resolution etc, so I'll play more and get something that
>> might be a bit less jittery. I could always adjust manually, because...
>>> Are you willing to give it a bit more of a tweak, or share the source
>>> files, so I can?
>> ...the rest of it is done in Inkscape...
>>> I like the names - possibly Bristol need a bit of location tweak.
>> ...and the names on a circle were a pain to do - which is why the bottom
>> of the circle isn't quite right compared to the top of the circle! But yes,
>> also a bit more spacing around the Bristol text is needed. I whipped this
>> out pretty quick and didn't have time to fine-tune everything, but if we
>> want to go with it I'll hone it!  Or pass it on to my "does a bit of
>> graphic design" girlfriend, but that would mean her staying late at work
>> for their Adobe license...
>>> We should also incorporate the event name in there somewhere - FOSS4G:UK
>>> Local 2023.
>> I think I was unsure about the name and I'm still worried about calling
>> it "UK" with Ireland in there! Let's not start a war...
>>> The swoop I like, will have to see how it all fits together.
>> Yeah, integrating the swoop into the map logo is a bit awkward, will
>> consider...
>>> Thanks,
>>> Nick.
>>> On 25/05/2023 11:47, Barry Rowlingson wrote:
>>> Thanks for the feedback and suggestions, here's the site map with
>>> upright text and locations marked as open circled.
>>> [image: image.png]
>>> I had a quick go at incorporating the national flags into the OSGeo
>>> swoosh. Note that there's no Northern Ireland flag in this but a) we don't
>>> have a location in NI and b) there is no official flag for Northern Ireland
>>> - the Ulster Banner and the St Patrick's Saltire are sometimes used but
>>> there's only four spaces in the swoosh...
>>> [image: image.png]
>>> On Wed, May 24, 2023 at 5:05 PM Dan Ormsby <dormsby at sparkgeo.com> wrote:
>>>> *This email originated outside the University. Check before clicking
>>>> links or attachments.*
>>>> Looks great Barry!  Vertically flipping the bottom 4 place names might
>>>> make it a bit easier to read and yes agree on the highlighted points for
>>>> venues.  It's only now that you mention it that I realise that is what was
>>>> done on last years logo!
>>>> Dan
>>>> On Wed, 24 May 2023 at 16:46, Barry Rowlingson <b.rowlingson at gmail.com>
>>>> wrote:
>>>>> Hi all, nice chat this morning, sets me thinking about various
>>>>> things...
>>>>> I like the logo with the dotmap of the UK and the locations coloured
>>>>> in, I assume the plan was to do this again but including Ireland and
>>>>> putting 7 dots in the right place for the seven locations? I'd suggest
>>>>> making the location dots clearer than the background dots, and giving the
>>>>> location names more prominence? Not sure if embedded images an non-plain
>>>>> text is allowed on this mailing list but (and I've not coloured the dots
>>>>> in...)
>>>>> [image: image.png]
>>>>> makes me think of one of those panorama viewpoint indicator things you
>>>>> get on the tops of hills showing you the places in the distance... which
>>>>> gives me another idea that's probably totally impractical...
>>>>> and in for a penny, here's a preliminary "ten years after" logo...
>>>>> [image: image.png]
>>>>> ok back to proper work now..
>>>>> Barry
>>>>> FOSS4G-UK mailing list
>>>>> FOSS4G-UK at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/foss4g-uk
>>>> I’m Dan Ormsby, UK Lead at *Sparkgeo*.
>>>> We provide geospatial expertise to tech companies.
>>>> Reach me at dormsby at sparkgeo.com or on LinkedIn
>>>> <https://www.linkedin.com/in/danielormsby/>
>>>> +44 7880794939
>>> Nick Bearman
>>> +44 (0) 7717745715nick at geospatialtrainingsolutions.co.uk
>>> Due to my own life/work balance, you may get emails from me outside of normal working hours. Please do not feel any pressure to respond outside of your own working pattern.
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230614/3645006f/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230614/3645006f/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230614/3645006f/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230614/3645006f/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230614/3645006f/attachment-0007.png>
More information about the FOSS4G-UK mailing list
