[FOSS4G-UK] [External] Re: Logo
Barry Rowlingson b.rowlingson at lancaster.ac.uk
Fri Jun 16 02:27:40 PDT 2023
I did a bit more tweaking, so now hovering over the text or sites invokes
the spirit of 2013...
You should be able to drop an SVG into any web page where you'd have an
image and get the hover functionality, but its easy enough for me to
produce PNG files from the SVG at any resolution you might need for static
display.
Updated here: https://b-rowlingson.gitlab.io/foss4guk2023/ (but not updated
the GIF version yet).
B
On Wed, Jun 14, 2023 at 11:56 AM Nick Bearman <
nick at geospatialtrainingsolutions.co.uk> wrote:
> Thanks very much Barry - looking really good.
> Hopefully we can incorporate the animated one into the website.
> One quick question - is the green hover blob the same colour as Ireland
> green? It looks a little different, but might be me. I will have a proper
> look when I am back next week.
> Any other comments from people?
> Best wishes,
> Nick.
> On 6/14/23 11:24, Barry Rowlingson wrote:
> I've added an animated gif version as well (during parts of a department
> meeting this morning...).
> Of course static PNG versions can be generated from the SVG - maybe the
> local groups will want to use images that highlight their location?
> To make the animation all I did was use Firefox' dev tools to trigger the
> "hover" style for each location and then use a screen-grab browser add-on,
> then use ImageMagick to make a gif.
> Barry
> On Tue, Jun 13, 2023 at 1:10 PM Barry Rowlingson <
> b.rowlingson at lancaster.ac.uk> wrote:
>> A day or so faffing with R and text on curves and SVG and CSS and...
>> Here's a logo:
>>  thoughts etc?
>> Barry
>> On Fri, Jun 9, 2023 at 8:17 AM Rowlingson, Barry <
>>> On Wed, Jun 7, 2023 at 4:35 PM Nick Bearman <
>>>> I'm not 100% sure about Ireland having a different colour and with the
>>>> dots being on the diagonal rather than on the straight (up and down) - one
>>>> or the other would be fine, I think both is a bit over kill. What do you
>>>> think?
>>> Yeah, I think as an exercise I tried both and left them both in! Just
>>> colour is probably better.
>>>> Also, something weird is happening between NI and Scotland - not sure
>>>> what the three dots are doing there.
>>> The dots are produced by QGIS' point-pattern fill style, so I'll ask it!
>>> I suspect there's some islands or something... I did a lot of adjustment of
>>> pattern fill offsets to try and get something that resembled last year's
>>> logo in terms of resolution etc, so I'll play more and get something that
>>> might be a bit less jittery. I could always adjust manually, because...
>>>> Are you willing to give it a bit more of a tweak, or share the source
>>>> files, so I can?
>>> ...the rest of it is done in Inkscape...
>>>> I like the names - possibly Bristol need a bit of location tweak.
>>> ...and the names on a circle were a pain to do - which is why the bottom
>>> of the circle isn't quite right compared to the top of the circle! But yes,
>>> also a bit more spacing around the Bristol text is needed. I whipped this
>>> out pretty quick and didn't have time to fine-tune everything, but if we
>>> want to go with it I'll hone it!  Or pass it on to my "does a bit of
>>> graphic design" girlfriend, but that would mean her staying late at work
>>> for their Adobe license...
>>>> We should also incorporate the event name in there somewhere -
>>>> FOSS4G:UK Local 2023.
>>> I think I was unsure about the name and I'm still worried about calling
>>> it "UK" with Ireland in there! Let's not start a war...
>>>> The swoop I like, will have to see how it all fits together.
>>> Yeah, integrating the swoop into the map logo is a bit awkward, will
>>> consider...
>>>> Thanks,
>>>> Nick.
>>>> On 25/05/2023 11:47, Barry Rowlingson wrote:
>>>> Thanks for the feedback and suggestions, here's the site map with
>>>> upright text and locations marked as open circled.
>>>> [image: image.png]
>>>> I had a quick go at incorporating the national flags into the OSGeo
>>>> swoosh. Note that there's no Northern Ireland flag in this but a) we don't
>>>> have a location in NI and b) there is no official flag for Northern Ireland
>>>> - the Ulster Banner and the St Patrick's Saltire are sometimes used but
>>>> there's only four spaces in the swoosh...
>>>> [image: image.png]
>>>> On Wed, May 24, 2023 at 5:05 PM Dan Ormsby <dormsby at sparkgeo.com>
>>>> wrote:
>>>>> *This email originated outside the University. Check before clicking
>>>>> links or attachments.*
>>>>> Looks great Barry!  Vertically flipping the bottom 4 place names might
>>>>> make it a bit easier to read and yes agree on the highlighted points for
>>>>> venues.  It's only now that you mention it that I realise that is what was
>>>>> done on last years logo!
>>>>> Dan
>>>>> On Wed, 24 May 2023 at 16:46, Barry Rowlingson <b.rowlingson at gmail.com>
>>>>> wrote:
>>>>>> Hi all, nice chat this morning, sets me thinking about various
>>>>>> things...
>>>>>> I like the logo with the dotmap of the UK and the locations coloured
>>>>>> in, I assume the plan was to do this again but including Ireland and
>>>>>> putting 7 dots in the right place for the seven locations? I'd suggest
>>>>>> making the location dots clearer than the background dots, and giving the
>>>>>> location names more prominence? Not sure if embedded images an non-plain
>>>>>> text is allowed on this mailing list but (and I've not coloured the dots
>>>>>> in...)
>>>>>> [image: image.png]
>>>>>> makes me think of one of those panorama viewpoint indicator things
>>>>>> you get on the tops of hills showing you the places in the distance...
>>>>>> which gives me another idea that's probably totally impractical...
>>>>>> and in for a penny, here's a preliminary "ten years after" logo...
>>>>>> [image: image.png]
>>>>>> ok back to proper work now..
>>>>>> Barry
>>>>>> FOSS4G-UK mailing list
>>>>>> FOSS4G-UK at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/foss4g-uk
>>>>> I’m Dan Ormsby, UK Lead at *Sparkgeo*.
>>>>> We provide geospatial expertise to tech companies.
>>>>> Reach me at dormsby at sparkgeo.com or on LinkedIn
>>>>> <https://www.linkedin.com/in/danielormsby/>
>>>>> +44 7880794939
>>>> Nick Bearman
>>>> +44 (0) 7717745715nick at geospatialtrainingsolutions.co.uk
>>>> Due to my own life/work balance, you may get emails from me outside of normal working hours. Please do not feel any pressure to respond outside of your own working pattern.
> Nick Bearman
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230616/afe6728b/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230616/afe6728b/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230616/afe6728b/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230616/afe6728b/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230616/afe6728b/attachment-0007.png>
More information about the FOSS4G-UK mailing list
