[FOSS4G-UK] [External] Re: Logo
Barry Rowlingson b.rowlingson at lancaster.ac.uk
Tue Jun 20 07:10:00 PDT 2023
No, don't change the SVG - you should scale it with CSS - and if you use
percentages it should scale with the page layout for mobile etc, although
maybe there's a separate stylesheet for mobile...
If I set width: 100% on the <object> then it fills the column, for example.
Barry
On Tue, Jun 20, 2023 at 3:00 PM Nick Bearman <
nick at geospatialtrainingsolutions.co.uk> wrote:
> Hi Barry / all,
> I'm trying to incorporate the logo in to the website, with a plan to
> launch the website after our meeting tomorrow.
> https://uk.osgeo.org/foss4guklocal2023/
> Currently I am having trouble shrinking the logo. I can change the width
> and height parameters in the SVG file (line 2) and I need it to be 270 px
> to fit, but it won't seem to shrink beyond 360 px (which is what it is
> showing at for me currently).
> Any ideas?
> I'm also planning on having the logo 'full size' on the home page, and
> then a small version in the navigation bar. Alternative arrangements are
> welcome :-)
> Best wishes,
> Nick.
> On 16/06/2023 10:27, Barry Rowlingson wrote:
> I did a bit more tweaking, so now hovering over the text or sites invokes
> the spirit of 2013...
> You should be able to drop an SVG into any web page where you'd have an
> image and get the hover functionality, but its easy enough for me to
> produce PNG files from the SVG at any resolution you might need for static
> display.
> Updated here: https://b-rowlingson.gitlab.io/foss4guk2023/ (but not
> updated the GIF version yet).
> B
> On Wed, Jun 14, 2023 at 11:56 AM Nick Bearman <
>> Thanks very much Barry - looking really good.
>> Hopefully we can incorporate the animated one into the website.
>> One quick question - is the green hover blob the same colour as Ireland
>> green? It looks a little different, but might be me. I will have a proper
>> look when I am back next week.
>> Any other comments from people?
>> Best wishes,
>> Nick.
>> On 6/14/23 11:24, Barry Rowlingson wrote:
>> I've added an animated gif version as well (during parts of a department
>> meeting this morning...).
>> Of course static PNG versions can be generated from the SVG - maybe the
>> local groups will want to use images that highlight their location?
>> To make the animation all I did was use Firefox' dev tools to trigger the
>> "hover" style for each location and then use a screen-grab browser add-on,
>> then use ImageMagick to make a gif.
>> Barry
>> On Tue, Jun 13, 2023 at 1:10 PM Barry Rowlingson <
>> b.rowlingson at lancaster.ac.uk> wrote:
>>> A day or so faffing with R and text on curves and SVG and CSS and...
>>> Here's a logo:
>>>  thoughts etc?
>>> Barry
>>> On Fri, Jun 9, 2023 at 8:17 AM Rowlingson, Barry <
>>>> On Wed, Jun 7, 2023 at 4:35 PM Nick Bearman <
>>>>> I'm not 100% sure about Ireland having a different colour and with the
>>>>> dots being on the diagonal rather than on the straight (up and down) - one
>>>>> or the other would be fine, I think both is a bit over kill. What do you
>>>>> think?
>>>> Yeah, I think as an exercise I tried both and left them both in! Just
>>>> colour is probably better.
>>>>> Also, something weird is happening between NI and Scotland - not sure
>>>>> what the three dots are doing there.
>>>> The dots are produced by QGIS' point-pattern fill style, so I'll ask
>>>> it! I suspect there's some islands or something... I did a lot of
>>>> adjustment of pattern fill offsets to try and get something that resembled
>>>> last year's logo in terms of resolution etc, so I'll play more and get
>>>> something that might be a bit less jittery. I could always adjust manually,
>>>> because...
>>>>> Are you willing to give it a bit more of a tweak, or share the source
>>>>> files, so I can?
>>>> ...the rest of it is done in Inkscape...
>>>>> I like the names - possibly Bristol need a bit of location tweak.
>>>> ...and the names on a circle were a pain to do - which is why the
>>>> bottom of the circle isn't quite right compared to the top of the circle!
>>>> But yes, also a bit more spacing around the Bristol text is needed. I
>>>> whipped this out pretty quick and didn't have time to fine-tune everything,
>>>> but if we want to go with it I'll hone it!  Or pass it on to my "does a bit
>>>> of graphic design" girlfriend, but that would mean her staying late at work
>>>> for their Adobe license...
>>>>> We should also incorporate the event name in there somewhere -
>>>>> FOSS4G:UK Local 2023.
>>>> I think I was unsure about the name and I'm still worried about calling
>>>> it "UK" with Ireland in there! Let's not start a war...
>>>>> The swoop I like, will have to see how it all fits together.
>>>> Yeah, integrating the swoop into the map logo is a bit awkward, will
>>>> consider...
>>>>> Thanks,
>>>>> Nick.
>>>>> On 25/05/2023 11:47, Barry Rowlingson wrote:
>>>>> Thanks for the feedback and suggestions, here's the site map with
>>>>> upright text and locations marked as open circled.
>>>>> [image: image.png]
>>>>> I had a quick go at incorporating the national flags into the OSGeo
>>>>> swoosh. Note that there's no Northern Ireland flag in this but a) we don't
>>>>> have a location in NI and b) there is no official flag for Northern Ireland
>>>>> - the Ulster Banner and the St Patrick's Saltire are sometimes used but
>>>>> there's only four spaces in the swoosh...
>>>>> [image: image.png]
>>>>> On Wed, May 24, 2023 at 5:05 PM Dan Ormsby <dormsby at sparkgeo.com>
>>>>> wrote:
>>>>>> *This email originated outside the University. Check before clicking
>>>>>> links or attachments.*
>>>>>> Looks great Barry!  Vertically flipping the bottom 4 place names
>>>>>> might make it a bit easier to read and yes agree on the highlighted points
>>>>>> for venues.  It's only now that you mention it that I realise that is what
>>>>>> was done on last years logo!
>>>>>> Dan
>>>>>> On Wed, 24 May 2023 at 16:46, Barry Rowlingson <
>>>>>> b.rowlingson at gmail.com> wrote:
>>>>>>> Hi all, nice chat this morning, sets me thinking about various
>>>>>>> things...
>>>>>>> I like the logo with the dotmap of the UK and the locations coloured
>>>>>>> in, I assume the plan was to do this again but including Ireland and
>>>>>>> putting 7 dots in the right place for the seven locations? I'd suggest
>>>>>>> making the location dots clearer than the background dots, and giving the
>>>>>>> location names more prominence? Not sure if embedded images an non-plain
>>>>>>> text is allowed on this mailing list but (and I've not coloured the dots
>>>>>>> in...)
>>>>>>> [image: image.png]
>>>>>>> makes me think of one of those panorama viewpoint indicator things
>>>>>>> you get on the tops of hills showing you the places in the distance...
>>>>>>> which gives me another idea that's probably totally impractical...
>>>>>>> and in for a penny, here's a preliminary "ten years after" logo...
>>>>>>> [image: image.png]
>>>>>>> ok back to proper work now..
>>>>>>> Barry
>>>>>>> FOSS4G-UK mailing list
>>>>>>> FOSS4G-UK at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/foss4g-uk
>>>>>> I’m Dan Ormsby, UK Lead at *Sparkgeo*.
>>>>>> We provide geospatial expertise to tech companies.
>>>>>> Reach me at dormsby at sparkgeo.com or on LinkedIn
>>>>>> <https://www.linkedin.com/in/danielormsby/>
>>>>>> +44 7880794939
>>>>> Nick Bearman
>>>>> +44 (0) 7717745715nick at geospatialtrainingsolutions.co.uk
>>>>> Due to my own life/work balance, you may get emails from me outside of normal working hours. Please do not feel any pressure to respond outside of your own working pattern.
>> Nick Bearman
> Nick Bearman
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230620/f159b4b5/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230620/f159b4b5/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230620/f159b4b5/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230620/f159b4b5/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230620/f159b4b5/attachment-0007.png>
More information about the FOSS4G-UK mailing list
