[FOSS4G-UK] [External] Re: Logo
Nick Bearman nick at geospatialtrainingsolutions.co.uk
Tue Jun 20 07:21:08 PDT 2023
Ok - thanks. I don't know how to do that.
Is someone willing to have a look at this? Ant perhaps, or someone else?
The site is at https://github.com/osgeouk/website, with some details in
the README there. Mini-site for FOSS4G:UK 2023 is in
https://github.com/osgeouk/website/tree/gh-pages/foss4guklocal2023.
Layout for nav bar is in
https://github.com/osgeouk/website/blob/gh-pages/_layouts/foss4guk2023.html.
Will add a temp placeholder for the moment.
Best wishes,
Nick.
On 20/06/2023 15:10, Barry Rowlingson wrote:
> No, don't change the SVG - you should scale it with CSS - and if you
> use percentages it should scale with the page layout for mobile etc,
> although maybe there's a separate stylesheet for mobile...
> If I set width: 100% on the <object> then it fills the column, for
> example.
> Barry
> On Tue, Jun 20, 2023 at 3:00 PM Nick Bearman
> <nick at geospatialtrainingsolutions.co.uk> wrote:
>     Hi Barry / all,
>     I'm trying to incorporate the logo in to the website, with a plan
>     to launch the website after our meeting tomorrow.
>     https://uk.osgeo.org/foss4guklocal2023/
>     Currently I am having trouble shrinking the logo. I can change the
>     width and height parameters in the SVG file (line 2) and I need it
>     to be 270 px to fit, but it won't seem to shrink beyond 360 px
>     (which is what it is showing at for me currently).
>     Any ideas?
>     I'm also planning on having the logo 'full size' on the home page,
>     and then a small version in the navigation bar. Alternative
>     arrangements are welcome :-)
>     Best wishes,
>     Nick.
>     On 16/06/2023 10:27, Barry Rowlingson wrote:
>>     I did a bit more tweaking, so now hovering over the text or sites
>>     invokes the spirit of 2013...
>>     You should be able to drop an SVG into any web page where you'd
>>     have an image and get the hover functionality, but its easy
>>     enough for me to produce PNG files from the SVG at any resolution
>>     you might need for static display.
>>     Updated here: https://b-rowlingson.gitlab.io/foss4guk2023/ (but
>>     not updated the GIF version yet).
>>     B
>>     On Wed, Jun 14, 2023 at 11:56 AM Nick Bearman
>>         Thanks very much Barry - looking really good.
>>         Hopefully we can incorporate the animated one into the website.
>>         One quick question - is the green hover blob the same colour
>>         as Ireland green? It looks a little different, but might be
>>         me. I will have a proper look when I am back next week.
>>         Any other comments from people?
>>         Best wishes,
>>         Nick.
>>         On 6/14/23 11:24, Barry Rowlingson wrote:
>>>         I've added an animated gif version as well (during parts of
>>>         a department meeting this morning...).
>>>         Of course static PNG versions can be generated from the SVG
>>>         - maybe the local groups will want to use images that
>>>         highlight their location?
>>>         To make the animation all I did was use Firefox' dev tools
>>>         to trigger the "hover" style for each location and then use
>>>         a screen-grab browser add-on, then use ImageMagick to make a
>>>         gif.
>>>         Barry
>>>         On Tue, Jun 13, 2023 at 1:10 PM Barry Rowlingson
>>>         <b.rowlingson at lancaster.ac.uk> wrote:
>>>             A day or so faffing with R and text on curves and SVG
>>>             and CSS and...
>>>             Here's a logo:
>>>              thoughts etc?
>>>             Barry
>>>             On Fri, Jun 9, 2023 at 8:17 AM Rowlingson, Barry
>>>                 On Wed, Jun 7, 2023 at 4:35 PM Nick Bearman
>>>                     I'm not 100% sure about Ireland having a
>>>                     different colour and with the dots being on the
>>>                     diagonal rather than on the straight (up and
>>>                     down) - one or the other would be fine, I think
>>>                     both is a bit over kill. What do you think?
>>>                 Yeah, I think as an exercise I tried both and left
>>>                 them both in! Just colour is probably better.
>>>                     Also, something weird is happening between NI
>>>                     and Scotland - not sure what the three dots are
>>>                     doing there.
>>>                 The dots are produced by QGIS' point-pattern fill
>>>                 style, so I'll ask it! I suspect there's some
>>>                 islands or something... I did a lot of adjustment of
>>>                 pattern fill offsets to try and get something that
>>>                 resembled last year's logo in terms of resolution
>>>                 etc, so I'll play more and get something that might
>>>                 be a bit less jittery. I could always adjust
>>>                 manually, because...
>>>                     Are you willing to give it a bit more of a
>>>                     tweak, or share the source files, so I can?
>>>                 ...the rest of it is done in Inkscape...
>>>                     I like the names - possibly Bristol need a bit
>>>                     of location tweak.
>>>                 ...and the names on a circle were a pain to do -
>>>                 which is why the bottom of the circle isn't quite
>>>                 right compared to the top of the circle! But yes,
>>>                 also a bit more spacing around the Bristol text is
>>>                 needed. I whipped this out pretty quick and didn't
>>>                 have time to fine-tune everything, but if we want to
>>>                 go with it I'll hone it! Or pass it on to my "does a
>>>                 bit of graphic design" girlfriend, but that would
>>>                 mean her staying late at work for their Adobe license...
>>>                     We should also incorporate the event name in
>>>                     there somewhere - FOSS4G:UK Local 2023.
>>>                 I think I was unsure about the name and I'm still
>>>                 worried about calling it "UK" with Ireland in there!
>>>                 Let's not start a war...
>>>                     The swoop I like, will have to see how it all
>>>                     fits together.
>>>                 Yeah, integrating the swoop into the map logo is a
>>>                 bit awkward, will consider...
>>>                     Thanks,
>>>                     Nick.
>>>                     On 25/05/2023 11:47, Barry Rowlingson wrote:
>>>>                     Thanks for the feedback and suggestions, here's
>>>>                     the site map with upright text and locations
>>>>                     marked as open circled.
>>>>                     I had a quick go at incorporating the national
>>>>                     flags into the OSGeo swoosh. Note that there's
>>>>                     no Northern Ireland flag in this but a) we
>>>>                     don't have a location in NI and b) there is no
>>>>                     official flag for Northern Ireland - the Ulster
>>>>                     Banner and the St Patrick's Saltire are
>>>>                     sometimes used but there's only four spaces in
>>>>                     the swoosh...
>>>>                     On Wed, May 24, 2023 at 5:05 PM Dan Ormsby
>>>>                     <dormsby at sparkgeo.com> wrote:
>>>>                         *This email originated outside the
>>>>                         University. Check before clicking links or
>>>>                         attachments.*
>>>>                         Looks great Barry! Vertically flipping the
>>>>                         bottom 4 place names might make it a bit
>>>>                         easier to read and yes agree on the
>>>>                         highlighted points for venues.  It's only
>>>>                         now that you mention it that I realise that
>>>>                         is what was done on last years logo!
>>>>                         Dan
>>>>                         On Wed, 24 May 2023 at 16:46, Barry
>>>>                         Rowlingson <b.rowlingson at gmail.com> wrote:
>>>>                             Hi all, nice chat this morning, sets me
>>>>                             thinking about various things...
>>>>                             I like the logo with the dotmap of the
>>>>                             UK and the locations coloured in, I
>>>>                             assume the plan was to do this again
>>>>                             but including Ireland and putting 7
>>>>                             dots in the right place for the seven
>>>>                             locations? I'd suggest making the
>>>>                             location dots clearer than the
>>>>                             background dots, and giving the
>>>>                             location names more prominence? Not
>>>>                             sure if embedded images an non-plain
>>>>                             text is allowed on this mailing list
>>>>                             but (and I've not coloured the dots in...)
>>>>                             makes me think of one of those panorama
>>>>                             viewpoint indicator things you get on
>>>>                             the tops of hills showing you the
>>>>                             places in the distance... which gives
>>>>                             me another idea that's probably totally
>>>>                             impractical...
>>>>                             and in for a penny, here's a
>>>>                             preliminary "ten years after" logo...
>>>>                             ok back to proper work now..
>>>>                             Barry
>>>>                             FOSS4G-UK mailing list
>>>>                             FOSS4G-UK at lists.osgeo.org
>>>>                             https://lists.osgeo.org/mailman/listinfo/foss4g-uk
>>>>                         I’m Dan Ormsby, UK Lead at *Sparkgeo*.
>>>>                         We provide geospatial expertise to tech
>>>>                         companies.
>>>>                         Reach me at dormsby at sparkgeo.com or on
>>>>                         LinkedIn
>>>>                         <https://www.linkedin.com/in/danielormsby/>
>>>>                         +44 7880794939
>>>                     Nick Bearman
>>>                     +44 (0) 7717745715
>>>                     Due to my own life/work balance, you may get emails from me outside of normal working hours. Please do not feel any pressure to respond outside of your own working pattern.
>>         Nick Bearman
>>         +44 (0) 7717745715
>     Nick Bearman
>     +44 (0) 7717745715
Nick Bearman
+44 (0) 7717745715
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230620/98a5a8d6/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230620/98a5a8d6/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230620/98a5a8d6/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230620/98a5a8d6/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230620/98a5a8d6/attachment-0007.png>
More information about the FOSS4G-UK mailing list
