[fusion-commits] r2415 - trunk/lib/Proj4js
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Jul 26 15:50:52 EDT 2011
Author: madair
Date: 2011-07-26 12:50:52 -0700 (Tue, 26 Jul 2011)
New Revision: 2415
   trunk/lib/Proj4js/proj4js-combined.js
   trunk/lib/Proj4js/proj4js-compressed.js
re #465: update Proj4js to v1.0.2
Modified: trunk/lib/Proj4js/proj4js-combined.js
--- trunk/lib/Proj4js/proj4js-combined.js	2011-07-22 18:54:29 UTC (rev 2414)
+++ trunk/lib/Proj4js/proj4js-combined.js	2011-07-26 19:50:52 UTC (rev 2415)
@@ -90,13 +90,18 @@
         // Workaround for Spherical Mercator
-        if ((source.srsProjNumber =="900913" && dest.datumCode != "WGS84") ||
-            (dest.srsProjNumber == "900913" && source.datumCode != "WGS84")) {
+        if ((source.srsProjNumber =="900913" && dest.datumCode != "WGS84" && !dest.datum_params) ||
+            (dest.srsProjNumber == "900913" && source.datumCode != "WGS84" && !source.datum_params)) {
             var wgs84 = Proj4js.WGS84;
             this.transform(source, wgs84, point);
             source = wgs84;
+        // DGR, 2010/11/12
+        if (source.axis!="enu") {
+            this.adjust_axis(source,false,point);
         // Transform source points to long/lat, if they aren't already.
         if ( source.projName=="longlat") {
             point.x *= Proj4js.common.D2R;  // convert degrees to radians
@@ -133,6 +138,12 @@
                 point.y /= dest.to_meter;
+        if (dest.axis!="enu") {
+            this.adjust_axis(dest,true,point);
         return point;
     }, // transform()
@@ -218,6 +229,50 @@
     }, // cs_datum_transform
+     * Function: adjust_axis
+     * Normalize or de-normalized the x/y/z axes.  The normal form is "enu"
+     * (easting, northing, up).
+     * Parameters:
+     * crs {Proj4js.Proj} the coordinate reference system
+     * denorm {Boolean} when false, normalize
+     * point {Object} the coordinates to adjust
+    adjust_axis: function(crs, denorm, point) {
+        var xin= point.x, yin= point.y, zin= point.z || 0.0;
+        var v, t;
+        for (var i= 0; i<3; i++) {
+            if (denorm && i==2 && point.z===undefined) { continue; }
+                 if (i==0) { v= xin; t= 'x'; }
+            else if (i==1) { v= yin; t= 'y'; }
+            else           { v= zin; t= 'z'; }
+            switch(crs.axis[i]) {
+            case 'e':
+                point[t]= v;
+                break;
+            case 'w':
+                point[t]= -v;
+                break;
+            case 'n':
+                point[t]= v;
+                break;
+            case 's':
+                point[t]= -v;
+                break;
+            case 'u':
+                if (point[t]!==undefined) { point.z= v; }
+                break;
+            case 'd':
+                if (point[t]!==undefined) { point.z= -v; }
+                break;
+            default :
+                alert("ERROR: unknow axis ("+crs.axis[i]+") - check definition of "+src.projName);
+                return null;
+        return point;
      * Function: reportError
      * An internal method to report errors back to user.
      * Override this in applications to report error messages or throw exceptions.
@@ -317,7 +372,8 @@
  * The following properties and methods handle dynamic loading of JSON objects.
      * Property: scriptName
      * {String} The filename of this script without any path.
@@ -471,23 +527,35 @@
   localCS: false,
-   * Constructor: initialize
-   * Constructor for Proj4js.Proj objects
+  * Property: queue
+  * Buffer (FIFO) to hold callbacks waiting to be called when projection loaded.
+  queue: null,
+  * Constructor: initialize
+  * Constructor for Proj4js.Proj objects
   * Parameters:
   * srsCode - a code for map projection definition parameters.  These are usually
   * (but not always) EPSG codes.
-  initialize: function(srsCode) {
+  initialize: function(srsCode, callback) {
       this.srsCodeInput = srsCode;
+      //Register callbacks prior to attempting to process definition
+      this.queue = [];
+      if( callback ){
+           this.queue.push( callback );
       //check to see if this is a WKT string
       if ((srsCode.indexOf('GEOGCS') >= 0) ||
           (srsCode.indexOf('GEOCCS') >= 0) ||
           (srsCode.indexOf('PROJCS') >= 0) ||
           (srsCode.indexOf('LOCAL_CS') >= 0)) {
             this.parseWKT(srsCode);
-            this.datum = new Proj4js.datum(this);
+            this.deriveConstants();
             this.loadProjCode(this.projName);
             return;
@@ -532,6 +600,7 @@
           this.srsAuth = '';
           this.srsProjNumber = this.srsCode;
       this.loadProjDefinition();
@@ -675,6 +744,12 @@
       Proj4js.extend(this, Proj4js.Proj[this.projName]);
       this.init();
       this.readyToUse = true;
+      if( this.queue ) {
+        var item;
+        while( (item = this.queue.shift()) ) {
+          item.call( this, this );
@@ -689,7 +764,12 @@
     var wktObject = wktMatch[1];
     var wktContent = wktMatch[2];
     var wktTemp = wktContent.split(",");
-    var wktName = wktTemp.shift();
+    var wktName;
+    if (wktObject.toUpperCase() == "TOWGS84") {
+      wktName = wktObject;  //no name supplied for the TOWGS84 array
+    } else {
+      wktName = wktTemp.shift();
     wktName = wktName.replace(/^\"/,"");
     wktName = wktName.replace(/\"$/,"");
@@ -759,9 +839,9 @@
         this.unitsPerMeter = parseFloat(wktArray.shift());
         break;
       case 'PARAMETER':
-        var name = wktName;
-        var value = parseFloat(parseFloat(wktArray.shift()));
-        //there amy be many variations on the wktName values, add in case
+        var name = wktName.toLowerCase();
+        var value = parseFloat(wktArray.shift());
+        //there may be many variations on the wktName values, add in case
         //statements as required
         switch (name) {
           case 'false_easting':
@@ -774,10 +854,10 @@
             this.k0 = value;
             break;
           case 'central_meridian':
-            this.long0 = value;
+            this.long0 = value*Proj4js.common.D2R;
             break;
           case 'latitude_of_origin':
-            this.lat0 = value;
+            this.lat0 = value*Proj4js.common.D2R;
             break;
           case 'more_here':
             break;
@@ -788,6 +868,27 @@
       case 'TOWGS84':
         this.datum_params = wktArray;
         break;
+      //DGR 2010-11-12: AXIS
+      case 'AXIS':
+        var name= wktName.toLowerCase();
+        var value= wktArray.shift();
+        switch (value) {
+          case 'EAST' : value= 'e'; break;
+          case 'WEST' : value= 'w'; break;
+          case 'NORTH': value= 'n'; break;
+          case 'SOUTH': value= 's'; break;
+          case 'UP'   : value= 'u'; break;
+          case 'DOWN' : value= 'd'; break;
+          case 'OTHER':
+          default     : value= ' '; break;//FIXME
+        if (!this.axis) { this.axis= "enu"; }
+        switch(name) {
+          case 'X': this.axis=                         value + this.axis.substr(1,2); break;
+          case 'Y': this.axis= this.axis.substr(0,1) + value + this.axis.substr(2,1); break;
+          case 'Z': this.axis= this.axis.substr(0,2) + value                        ; break;
+          default : break;
       case 'MORE_HERE':
         break;
       default:
@@ -852,6 +953,16 @@
                                 Proj4js.PrimeMeridian[paramVal] : parseFloat(paramVal);
                              this.from_greenwich *= Proj4js.common.D2R;
                              break;
+              // DGR 2010-11-12: axis
+              case "axis":   paramVal = paramVal.replace(/\s/gi,"");
+                             var legalAxis= "ewnsud";
+                             if (paramVal.length==3 &&
+                                 legalAxis.indexOf(paramVal.substr(0,1))!=-1 &&
+                                 legalAxis.indexOf(paramVal.substr(1,1))!=-1 &&
+                                 legalAxis.indexOf(paramVal.substr(2,1))!=-1) {
+                                this.axis= paramVal;
+                             } //FIXME: be silent ?
+                             break
               case "no_defs": break;
               default: //alert("Unrecognized parameter: " + paramName);
           } // switch()
@@ -896,6 +1007,8 @@
       this.ep2=(this.a2-this.b2)/this.b2; // used in geocentric
       if (!this.k0) this.k0 = 1.0;    //default value
+      //DGR 2010-11-12: axis
@@ -1313,7 +1426,7 @@
  * Following iterative algorithm was developped by
- * "Institut für Erdmessung", University of Hannover, July 1988.
+ * "Institut f�r Erdmessung", University of Hannover, July 1988.
  * Internet: www.ife.uni-hannover.de
  * Iterative computation of CPHI,SPHI and Height.
  * Iteration of CPHI and SPHI to 10**-12 radian resp.
@@ -1550,7 +1663,7 @@
         this.x = x[0];
         this.y = x[1];
         this.z = x[2] || 0.0;
-      } else if (typeof x == 'string') {
+      } else if (typeof x == 'string' && typeof y == 'undefined') {
         var coords = x.split(',');
         this.x = parseFloat(coords[0]);
         this.y = parseFloat(coords[1]);
@@ -1680,6 +1793,7 @@
 Proj4js.wktProjections = {
   "Lambert Tangential Conformal Conic Projection": "lcc",
   "Mercator": "merc",
+  "Popular Visualisation Pseudo Mercator": "merc",
   "Transverse_Mercator": "tmerc",
   "Transverse Mercator": "tmerc",
   "Lambert Azimuthal Equal Area": "laea",
@@ -3087,6 +3201,8 @@
     		lon = (x == 0. && y == 0.) ? 0. : Math.atan2(x, y);
     		break;
+        p.x = Proj4js.common.adjust_lon(lon + this.long0);
+        p.y = lat;
     } else {
     	rho = Math.sqrt(x*x + y*y);
     	switch (this.mode) {
@@ -4701,6 +4817,7 @@
         cosphi = Math.cos(phi);
         coslam = Math.cos(lam);
+          case this.OBLIQ:
           case this.EQUIT:
             y = (this.mode == this.EQUIT) ? 1. + cosphi * coslam : 1. + this.sinph0 * sinphi + this.cosph0 * cosphi * coslam;
             if (y <= Proj4js.common.EPSLN) {
Modified: trunk/lib/Proj4js/proj4js-compressed.js
--- trunk/lib/Proj4js/proj4js-compressed.js	2011-07-22 18:54:29 UTC (rev 2414)
+++ trunk/lib/Proj4js/proj4js-compressed.js	2011-07-26 19:50:52 UTC (rev 2415)
@@ -11,12 +11,14 @@
 Proj4js={defaultDatum:'WGS84',transform:function(source,dest,point){if(!source.readyToUse){this.reportError("Proj4js initialization for:"+source.srsCode+" not yet complete");return point;}
 if(!dest.readyToUse){this.reportError("Proj4js initialization for:"+dest.srsCode+" not yet complete");return point;}
-if((source.srsProjNumber=="900913"&&dest.datumCode!="WGS84")||(dest.srsProjNumber=="900913"&&source.datumCode!="WGS84")){var wgs84=Proj4js.WGS84;this.transform(source,wgs84,point);source=wgs84;}
+if((source.srsProjNumber=="900913"&&dest.datumCode!="WGS84"&&!dest.datum_params)||(dest.srsProjNumber=="900913"&&source.datumCode!="WGS84"&&!source.datum_params)){var wgs84=Proj4js.WGS84;this.transform(source,wgs84,point);source=wgs84;}
+if(source.axis!="enu"){this.adjust_axis(source,false,point);}
 if(source.projName=="longlat"){point.x*=Proj4js.common.D2R;point.y*=Proj4js.common.D2R;}else{if(source.to_meter){point.x*=source.to_meter;point.y*=source.to_meter;}
 source.inverse(point);}
 if(source.from_greenwich){point.x+=source.from_greenwich;}
 point=this.datum_transform(source.datum,dest.datum,point);if(dest.from_greenwich){point.x-=dest.from_greenwich;}
 if(dest.projName=="longlat"){point.x*=Proj4js.common.R2D;point.y*=Proj4js.common.R2D;}else{dest.forward(point);if(dest.to_meter){point.x/=dest.to_meter;point.y/=dest.to_meter;}}
+if(dest.axis!="enu"){this.adjust_axis(dest,true,point);}
 return point;},datum_transform:function(source,dest,point){if(source.compare_datums(dest)){return point;}
 if(source.datum_type==Proj4js.common.PJD_NODATUM||dest.datum_type==Proj4js.common.PJD_NODATUM){return point;}
 if(source.datum_type==Proj4js.common.PJD_GRIDSHIFT)
@@ -29,30 +31,45 @@
 dest.geocentric_to_geodetic(point);}
 if(dest.datum_type==Proj4js.common.PJD_GRIDSHIFT)
 {alert("ERROR: Grid shift transformations are not implemented yet.");}
+return point;},adjust_axis:function(crs,denorm,point){var xin=point.x,yin=point.y,zin=point.z||0.0;var v,t;for(var i=0;i<3;i++){if(denorm&&i==2&&point.z===undefined){continue;}
+if(i==0){v=xin;t='x';}
+else if(i==1){v=yin;t='y';}
+else{v=zin;t='z';}
+switch(crs.axis[i]){case'e':point[t]=v;break;case'w':point[t]=-v;break;case'n':point[t]=v;break;case's':point[t]=-v;break;case'u':if(point[t]!==undefined){point.z=v;}
+break;case'd':if(point[t]!==undefined){point.z=-v;}
+break;default:alert("ERROR: unknow axis ("+crs.axis[i]+") - check definition of "+src.projName);return null;}}
 return point;},reportError:function(msg){},extend:function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}}
 return destination;},Class:function(){var Class=function(){this.initialize.apply(this,arguments);};var extended={};var parent;for(var i=0;i<arguments.length;++i){if(typeof arguments[i]=="function"){parent=arguments[i].prototype;}else{parent=arguments[i];}
 Proj4js.extend(extended,parent);}
 Class.prototype=extended;return Class;},bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},scriptName:"proj4js-compressed.js",defsLookupService:'http://spatialreference.org/ref',libPath:null,getScriptLocation:function(){if(this.libPath)return this.libPath;var scriptName=this.scriptName;var scriptNameLen=scriptName.length;var scripts=document.getElementsByTagName('script');for(var i=0;i<scripts.length;i++){var src=scripts[i].getAttribute('src');if(src){var index=src.lastIndexOf(scriptName);if((index>-1)&&(index+scriptNameLen==src.length)){this.libPath=src.slice(0,-scriptNameLen);break;}}}
 return this.libPath||"";},loadScript:function(url,onload,onfail,loadCheck){var script=document.createElement('script');script.defer=false;script.type="text/javascript";script.id=url;script.src=url;script.onload=onload;script.onerror=onfail;script.loadCheck=loadCheck;if(/MSIE/.test(navigator.userAgent)){script.onreadystatechange=this.checkReadyState;}
-document.getElementsByTagName('head')[0].appendChild(script);},checkReadyState:function(){if(this.readyState=='loaded'){if(!this.loadCheck()){this.onerror();}else{this.onload();}}}};Proj4js.Proj=Proj4js.Class({readyToUse:false,title:null,projName:null,units:null,datum:null,x0:0,y0:0,localCS:false,initialize:function(srsCode){this.srsCodeInput=srsCode;if((srsCode.indexOf('GEOGCS')>=0)||(srsCode.indexOf('GEOCCS')>=0)||(srsCode.indexOf('PROJCS')>=0)||(srsCode.indexOf('LOCAL_CS')>=0)){this.parseWKT(srsCode);this.datum=new Proj4js.datum(this);this.loadProjCode(this.projName);return;}
+document.getElementsByTagName('head')[0].appendChild(script);},checkReadyState:function(){if(this.readyState=='loaded'){if(!this.loadCheck()){this.onerror();}else{this.onload();}}}};Proj4js.Proj=Proj4js.Class({readyToUse:false,title:null,projName:null,units:null,datum:null,x0:0,y0:0,localCS:false,queue:null,initialize:function(srsCode,callback){this.srsCodeInput=srsCode;this.queue=[];if(callback){this.queue.push(callback);}
+if((srsCode.indexOf('GEOGCS')>=0)||(srsCode.indexOf('GEOCCS')>=0)||(srsCode.indexOf('PROJCS')>=0)||(srsCode.indexOf('LOCAL_CS')>=0)){this.parseWKT(srsCode);this.deriveConstants();this.loadProjCode(this.projName);return;}
 if(srsCode.indexOf('urn:')==0){var urn=srsCode.split(':');if((urn[1]=='ogc'||urn[1]=='x-ogc')&&(urn[2]=='def')&&(urn[3]=='crs')){srsCode=urn[4]+':'+urn[urn.length-1];}}else if(srsCode.indexOf('http://')==0){var url=srsCode.split('#');if(url[0].match(/epsg.org/)){srsCode='EPSG:'+url[1];}else if(url[0].match(/RIG.xml/)){srsCode='IGNF:'+url[1];}}
 this.srsCode=srsCode.toUpperCase();if(this.srsCode.indexOf("EPSG")==0){this.srsCode=this.srsCode;this.srsAuth='epsg';this.srsProjNumber=this.srsCode.substring(5);}else if(this.srsCode.indexOf("IGNF")==0){this.srsCode=this.srsCode;this.srsAuth='IGNF';this.srsProjNumber=this.srsCode.substring(5);}else if(this.srsCode.indexOf("CRS")==0){this.srsCode=this.srsCode;this.srsAuth='CRS';this.srsProjNumber=this.srsCode.substring(4);}else{this.srsAuth='';this.srsProjNumber=this.srsCode;}
 this.loadProjDefinition();},loadProjDefinition:function(){if(Proj4js.defs[this.srsCode]){this.defsLoaded();return;}
 var url=Proj4js.getScriptLocation()+'defs/'+this.srsAuth.toUpperCase()+this.srsProjNumber+'.js';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.loadFromService,this),Proj4js.bind(this.checkDefsLoaded,this));},loadFromService:function(){var url=Proj4js.defsLookupService+'/'+this.srsAuth+'/'+this.srsProjNumber+'/proj4js/';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.defsFailed,this),Proj4js.bind(this.checkDefsLoaded,this));},defsLoaded:function(){this.parseDefs();this.loadProjCode(this.projName);},checkDefsLoaded:function(){if(Proj4js.defs[this.srsCode]){return true;}else{return false;}},defsFailed:function(){Proj4js.reportError('failed to load projection definition for: '+this.srsCode);Proj4js.defs[this.srsCode]=Proj4js.defs['WGS84'];this.defsLoaded();},loadProjCode:function(projName){if(Proj4js.Proj[projName]){this.initTransforms();return;}
-var url=Proj4js.getScriptLocation()+'projCode/'+projName+'.js';Proj4js.loadScript(url,Proj4js.bind(this.loadProjCodeSuccess,this,projName),Proj4js.bind(this.loadProjCodeFailure,this,projName),Proj4js.bind(this.checkCodeLoaded,this,projName));},loadProjCodeSuccess:function(projName){if(Proj4js.Proj[projName].dependsOn){this.loadProjCode(Proj4js.Proj[projName].dependsOn);}else{this.initTransforms();}},loadProjCodeFailure:function(projName){Proj4js.reportError("failed to find projection file for: "+projName);},checkCodeLoaded:function(projName){if(Proj4js.Proj[projName]){return true;}else{return false;}},initTransforms:function(){Proj4js.extend(this,Proj4js.Proj[this.projName]);this.init();this.readyToUse=true;},wktRE:/^(\w+)\[(.*)\]$/,parseWKT:function(wkt){var wktMatch=wkt.match(this.wktRE);if(!wktMatch)return;var wktObject=wktMatch[1];var wktContent=wktMatch[2];var wktTemp=wktContent.split(",");var wktName=wktTemp.shift();wktName=wktName.replace(/^\"/,"");wktName=wktName.rep
 lace(/\"$/,"");var wktArray=new Array();var bkCount=0;var obj="";for(var i=0;i<wktTemp.length;++i){var token=wktTemp[i];for(var j=0;j<token.length;++j){if(token.charAt(j)=="[")++bkCount;if(token.charAt(j)=="]")--bkCount;}
+var url=Proj4js.getScriptLocation()+'projCode/'+projName+'.js';Proj4js.loadScript(url,Proj4js.bind(this.loadProjCodeSuccess,this,projName),Proj4js.bind(this.loadProjCodeFailure,this,projName),Proj4js.bind(this.checkCodeLoaded,this,projName));},loadProjCodeSuccess:function(projName){if(Proj4js.Proj[projName].dependsOn){this.loadProjCode(Proj4js.Proj[projName].dependsOn);}else{this.initTransforms();}},loadProjCodeFailure:function(projName){Proj4js.reportError("failed to find projection file for: "+projName);},checkCodeLoaded:function(projName){if(Proj4js.Proj[projName]){return true;}else{return false;}},initTransforms:function(){Proj4js.extend(this,Proj4js.Proj[this.projName]);this.init();this.readyToUse=true;if(this.queue){var item;while((item=this.queue.shift())){item.call(this,this);}}},wktRE:/^(\w+)\[(.*)\]$/,parseWKT:function(wkt){var wktMatch=wkt.match(this.wktRE);if(!wktMatch)return;var wktObject=wktMatch[1];var wktContent=wktMatch[2];var wktTemp=wktContent.split(",");v
 ar wktName;if(wktObject.toUpperCase()=="TOWGS84"){wktName=wktObject;}else{wktName=wktTemp.shift();}
+wktName=wktName.replace(/^\"/,"");wktName=wktName.replace(/\"$/,"");var wktArray=new Array();var bkCount=0;var obj="";for(var i=0;i<wktTemp.length;++i){var token=wktTemp[i];for(var j=0;j<token.length;++j){if(token.charAt(j)=="[")++bkCount;if(token.charAt(j)=="]")--bkCount;}
 obj+=token;if(bkCount===0){wktArray.push(obj);obj="";}else{obj+=",";}}
 switch(wktObject){case'LOCAL_CS':this.projName='identity'
 this.localCS=true;this.srsCode=wktName;break;case'GEOGCS':this.projName='longlat'
 this.geocsCode=wktName;if(!this.srsCode)this.srsCode=wktName;break;case'PROJCS':this.srsCode=wktName;break;case'GEOCCS':break;case'PROJECTION':this.projName=Proj4js.wktProjections[wktName]
-break;case'DATUM':this.datumName=wktName;break;case'LOCAL_DATUM':this.datumCode='none';break;case'SPHEROID':this.ellps=wktName;this.a=parseFloat(wktArray.shift());this.rf=parseFloat(wktArray.shift());break;case'PRIMEM':this.from_greenwich=parseFloat(wktArray.shift());break;case'UNIT':this.units=wktName;this.unitsPerMeter=parseFloat(wktArray.shift());break;case'PARAMETER':var name=wktName;var value=parseFloat(parseFloat(wktArray.shift()));switch(name){case'false_easting':this.x0=value;break;case'false_northing':this.y0=value;break;case'scale_factor':this.k0=value;break;case'central_meridian':this.long0=value;break;case'latitude_of_origin':this.lat0=value;break;case'more_here':break;default:break;}
-break;case'TOWGS84':this.datum_params=wktArray;break;case'MORE_HERE':break;default:break;}
+break;case'DATUM':this.datumName=wktName;break;case'LOCAL_DATUM':this.datumCode='none';break;case'SPHEROID':this.ellps=wktName;this.a=parseFloat(wktArray.shift());this.rf=parseFloat(wktArray.shift());break;case'PRIMEM':this.from_greenwich=parseFloat(wktArray.shift());break;case'UNIT':this.units=wktName;this.unitsPerMeter=parseFloat(wktArray.shift());break;case'PARAMETER':var name=wktName.toLowerCase();var value=parseFloat(wktArray.shift());switch(name){case'false_easting':this.x0=value;break;case'false_northing':this.y0=value;break;case'scale_factor':this.k0=value;break;case'central_meridian':this.long0=value*Proj4js.common.D2R;break;case'latitude_of_origin':this.lat0=value*Proj4js.common.D2R;break;case'more_here':break;default:break;}
+break;case'TOWGS84':this.datum_params=wktArray;break;case'AXIS':var name=wktName.toLowerCase();var value=wktArray.shift();switch(value){case'EAST':value='e';break;case'WEST':value='w';break;case'NORTH':value='n';break;case'SOUTH':value='s';break;case'UP':value='u';break;case'DOWN':value='d';break;case'OTHER':default:value=' ';break;}
+if(!this.axis){this.axis="enu";}
+switch(name){case'X':this.axis=value+this.axis.substr(1,2);break;case'Y':this.axis=this.axis.substr(0,1)+value+this.axis.substr(2,1);break;case'Z':this.axis=this.axis.substr(0,2)+value;break;default:break;}
+case'MORE_HERE':break;default:break;}
 for(var i=0;i<wktArray.length;++i){this.parseWKT(wktArray[i]);}},parseDefs:function(){this.defData=Proj4js.defs[this.srsCode];var paramName,paramVal;if(!this.defData){return;}
-var paramArray=this.defData.split("+");for(var prop=0;prop<paramArray.length;prop++){var property=paramArray[prop].split("=");paramName=property[0].toLowerCase();paramVal=property[1];switch(paramName.replace(/\s/gi,"")){case"":break;case"title":this.title=paramVal;break;case"proj":this.projName=paramVal.replace(/\s/gi,"");break;case"units":this.units=paramVal.replace(/\s/gi,"");break;case"datum":this.datumCode=paramVal.replace(/\s/gi,"");break;case"nadgrids":this.nagrids=paramVal.replace(/\s/gi,"");break;case"ellps":this.ellps=paramVal.replace(/\s/gi,"");break;case"a":this.a=parseFloat(paramVal);break;case"b":this.b=parseFloat(paramVal);break;case"rf":this.rf=parseFloat(paramVal);break;case"lat_0":this.lat0=paramVal*Proj4js.common.D2R;break;case"lat_1":this.lat1=paramVal*Proj4js.common.D2R;break;case"lat_2":this.lat2=paramVal*Proj4js.common.D2R;break;case"lat_ts":this.lat_ts=paramVal*Proj4js.common.D2R;break;case"lon_0":this.long0=paramVal*Proj4js.common.D2R;break;case"alpha
 ":this.alpha=parseFloat(paramVal)*Proj4js.common.D2R;break;case"lonc":this.longc=paramVal*Proj4js.common.D2R;break;case"x_0":this.x0=parseFloat(paramVal);break;case"y_0":this.y0=parseFloat(paramVal);break;case"k_0":this.k0=parseFloat(paramVal);break;case"k":this.k0=parseFloat(paramVal);break;case"r_a":this.R_A=true;break;case"zone":this.zone=parseInt(paramVal);break;case"south":this.utmSouth=true;break;case"towgs84":this.datum_params=paramVal.split(",");break;case"to_meter":this.to_meter=parseFloat(paramVal);break;case"from_greenwich":this.from_greenwich=paramVal*Proj4js.common.D2R;break;case"pm":paramVal=paramVal.replace(/\s/gi,"");this.from_greenwich=Proj4js.PrimeMeridian[paramVal]?Proj4js.PrimeMeridian[paramVal]:parseFloat(paramVal);this.from_greenwich*=Proj4js.common.D2R;break;case"no_defs":break;default:}}
+var paramArray=this.defData.split("+");for(var prop=0;prop<paramArray.length;prop++){var property=paramArray[prop].split("=");paramName=property[0].toLowerCase();paramVal=property[1];switch(paramName.replace(/\s/gi,"")){case"":break;case"title":this.title=paramVal;break;case"proj":this.projName=paramVal.replace(/\s/gi,"");break;case"units":this.units=paramVal.replace(/\s/gi,"");break;case"datum":this.datumCode=paramVal.replace(/\s/gi,"");break;case"nadgrids":this.nagrids=paramVal.replace(/\s/gi,"");break;case"ellps":this.ellps=paramVal.replace(/\s/gi,"");break;case"a":this.a=parseFloat(paramVal);break;case"b":this.b=parseFloat(paramVal);break;case"rf":this.rf=parseFloat(paramVal);break;case"lat_0":this.lat0=paramVal*Proj4js.common.D2R;break;case"lat_1":this.lat1=paramVal*Proj4js.common.D2R;break;case"lat_2":this.lat2=paramVal*Proj4js.common.D2R;break;case"lat_ts":this.lat_ts=paramVal*Proj4js.common.D2R;break;case"lon_0":this.long0=paramVal*Proj4js.common.D2R;break;case"alpha
 ":this.alpha=parseFloat(paramVal)*Proj4js.common.D2R;break;case"lonc":this.longc=paramVal*Proj4js.common.D2R;break;case"x_0":this.x0=parseFloat(paramVal);break;case"y_0":this.y0=parseFloat(paramVal);break;case"k_0":this.k0=parseFloat(paramVal);break;case"k":this.k0=parseFloat(paramVal);break;case"r_a":this.R_A=true;break;case"zone":this.zone=parseInt(paramVal);break;case"south":this.utmSouth=true;break;case"towgs84":this.datum_params=paramVal.split(",");break;case"to_meter":this.to_meter=parseFloat(paramVal);break;case"from_greenwich":this.from_greenwich=paramVal*Proj4js.common.D2R;break;case"pm":paramVal=paramVal.replace(/\s/gi,"");this.from_greenwich=Proj4js.PrimeMeridian[paramVal]?Proj4js.PrimeMeridian[paramVal]:parseFloat(paramVal);this.from_greenwich*=Proj4js.common.D2R;break;case"axis":paramVal=paramVal.replace(/\s/gi,"");var legalAxis="ewnsud";if(paramVal.length==3&&legalAxis.indexOf(paramVal.substr(0,1))!=-1&&legalAxis.indexOf(paramVal.substr(1,1))!=-1&&legalAxis.ind
 exOf(paramVal.substr(2,1))!=-1){this.axis=paramVal;}
+break
+case"no_defs":break;default:}}
 this.deriveConstants();},deriveConstants:function(){if(this.nagrids=='@null')this.datumCode='none';if(this.datumCode&&this.datumCode!='none'){var datumDef=Proj4js.Datum[this.datumCode];if(datumDef){this.datum_params=datumDef.towgs84?datumDef.towgs84.split(','):null;this.ellps=datumDef.ellipse;this.datumName=datumDef.datumName?datumDef.datumName:this.datumCode;}}
 if(!this.a){var ellipse=Proj4js.Ellipsoid[this.ellps]?Proj4js.Ellipsoid[this.ellps]:Proj4js.Ellipsoid['WGS84'];Proj4js.extend(this,ellipse);}
 if(this.rf&&!this.b)this.b=(1.0-1.0/this.rf)*this.a;if(Math.abs(this.a-this.b)<Proj4js.common.EPSLN){this.sphere=true;this.b=this.a;}
 this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=(this.a2-this.b2)/this.a2;this.e=Math.sqrt(this.es);if(this.R_A){this.a*=1.-this.es*(Proj4js.common.SIXTH+this.es*(Proj4js.common.RA4+this.es*Proj4js.common.RA6));this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=0.;}
-this.ep2=(this.a2-this.b2)/this.b2;if(!this.k0)this.k0=1.0;this.datum=new Proj4js.datum(this);}});Proj4js.Proj.longlat={init:function(){},forward:function(pt){return pt;},inverse:function(pt){return pt;}};Proj4js.Proj.identity=Proj4js.Proj.longlat;Proj4js.defs={'WGS84':"+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4326':"+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4269':"+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees",'EPSG:3785':"+title= Google Mercator +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"};Proj4js.defs['GOOGLE']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:900913']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:102113']=Proj4js.defs['EPSG:3785'];Proj4js.common={PI:3.141592653589793238,HALF_PI:1.570796326794896619,TWO_PI:6.28318
 5307179586477,FORTPI:0.78539816339744833,R2D:57.29577951308232088,D2R:0.01745329251994329577,SEC_TO_RAD:4.84813681109535993589914102357e-6,EPSLN:1.0e-10,MAX_ITER:20,COS_67P5:0.38268343236508977,AD_C:1.0026000,PJD_UNKNOWN:0,PJD_3PARAM:1,PJD_7PARAM:2,PJD_GRIDSHIFT:3,PJD_WGS84:4,PJD_NODATUM:5,SRS_WGS84_SEMIMAJOR:6378137.0,SIXTH:.1666666666666666667,RA4:.04722222222222222222,RA6:.02215608465608465608,RV4:.06944444444444444444,RV6:.04243827160493827160,msfnz:function(eccent,sinphi,cosphi){var con=eccent*sinphi;return cosphi/(Math.sqrt(1.0-con*con));},tsfnz:function(eccent,phi,sinphi){var con=eccent*sinphi;var com=.5*eccent;con=Math.pow(((1.0-con)/(1.0+con)),com);return(Math.tan(.5*(this.HALF_PI-phi))/con);},phi2z:function(eccent,ts){var eccnth=.5*eccent;var con,dphi;var phi=this.HALF_PI-2*Math.atan(ts);for(var i=0;i<=15;i++){con=eccent*Math.sin(phi);dphi=this.HALF_PI-2*Math.atan(ts*(Math.pow(((1.0-con)/(1.0+con)),eccnth)))-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001)return phi;}
+this.ep2=(this.a2-this.b2)/this.b2;if(!this.k0)this.k0=1.0;if(!this.axis){this.axis="enu";}
+this.datum=new Proj4js.datum(this);}});Proj4js.Proj.longlat={init:function(){},forward:function(pt){return pt;},inverse:function(pt){return pt;}};Proj4js.Proj.identity=Proj4js.Proj.longlat;Proj4js.defs={'WGS84':"+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4326':"+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4269':"+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees",'EPSG:3785':"+title= Google Mercator +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"};Proj4js.defs['GOOGLE']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:900913']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:102113']=Proj4js.defs['EPSG:3785'];Proj4js.common={PI:3.141592653589793238,HALF_PI:1.570796326794896619,TWO_PI:6.283185307179586477,FORTPI:0.78539816339744833,R2D:57.29577951308
 alert("phi2z has NoConvergence");return(-9999);},qsfnz:function(eccent,sinphi){var con;if(eccent>1.0e-7){con=eccent*sinphi;return((1.0-eccent*eccent)*(sinphi/(1.0-con*con)-(.5/eccent)*Math.log((1.0-con)/(1.0+con))));}else{return(2.0*sinphi);}},asinz:function(x){if(Math.abs(x)>1.0){x=(x>1.0)?1.0:-1.0;}
 return Math.asin(x);},e0fn:function(x){return(1.0-0.25*x*(1.0+x/16.0*(3.0+1.25*x)));},e1fn:function(x){return(0.375*x*(1.0+0.25*x*(1.0+0.46875*x)));},e2fn:function(x){return(0.05859375*x*x*(1.0+0.75*x));},e3fn:function(x){return(x*x*x*(35.0/3072.0));},mlfn:function(e0,e1,e2,e3,phi){return(e0*phi-e1*Math.sin(2.0*phi)+e2*Math.sin(4.0*phi)-e3*Math.sin(6.0*phi));},srat:function(esinp,exp){return(Math.pow((1.0-esinp)/(1.0+esinp),exp));},sign:function(x){if(x<0.0)return(-1);else return(1);},adjust_lon:function(x){x=(Math.abs(x)<this.PI)?x:(x-(this.sign(x)*this.TWO_PI));return x;},adjust_lat:function(x){x=(Math.abs(x)<this.HALF_PI)?x:(x-(this.sign(x)*this.PI));return x;},latiso:function(eccent,phi,sinphi){if(Math.abs(phi)>this.HALF_PI)return+Number.NaN;if(phi==this.HALF_PI)return Number.POSITIVE_INFINITY;if(phi==-1.0*this.HALF_PI)return-1.0*Number.POSITIVE_INFINITY;var con=eccent*sinphi;return Math.log(Math.tan((this.HALF_PI+phi)/2.0))+eccent*Math.log((1.0-con)/(1.0+con))/2.0;},fL:
 function(x,L){return 2.0*Math.atan(x*Math.exp(L))-this.HALF_PI;},invlatiso:function(eccent,ts){var phi=this.fL(1.0,ts);var Iphi=0.0;var con=0.0;do{Iphi=phi;con=eccent*Math.sin(Iphi);phi=this.fL(Math.exp(eccent*Math.log((1.0+con)/(1.0-con))/2.0),ts)}while(Math.abs(phi-Iphi)>1.0e-12);return phi;},sinh:function(x)
 {var r=Math.exp(x);r=(r-1.0/r)/2.0;return r;},cosh:function(x)
@@ -97,7 +114,7 @@
 {var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_out=M_BF*(p.x-Rz_BF*p.y+Ry_BF*p.z)+Dx_BF;var y_out=M_BF*(Rz_BF*p.x+p.y-Rx_BF*p.z)+Dy_BF;var z_out=M_BF*(-Ry_BF*p.x+Rx_BF*p.y+p.z)+Dz_BF;p.x=x_out;p.y=y_out;p.z=z_out;}},geocentric_from_wgs84:function(p){if(this.datum_type==Proj4js.common.PJD_3PARAM)
 {p.x-=this.datum_params[0];p.y-=this.datum_params[1];p.z-=this.datum_params[2];}
 else if(this.datum_type==Proj4js.common.PJD_7PARAM)
-{var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_tmp=(p.x-Dx_BF)/M_BF;var y_tmp=(p.y-Dy_BF)/M_BF;var z_tmp=(p.z-Dz_BF)/M_BF;p.x=x_tmp+Rz_BF*y_tmp-Ry_BF*z_tmp;p.y=-Rz_BF*x_tmp+y_tmp+Rx_BF*z_tmp;p.z=Ry_BF*x_tmp-Rx_BF*y_tmp+z_tmp;}}});Proj4js.Point=Proj4js.Class({initialize:function(x,y,z){if(typeof x=='object'){this.x=x[0];this.y=x[1];this.z=x[2]||0.0;}else if(typeof x=='string'){var coords=x.split(',');this.x=parseFloat(coords[0]);this.y=parseFloat(coords[1]);this.z=parseFloat(coords[2])||0.0;}else{this.x=x;this.y=y;this.z=z||0.0;}},clone:function(){return new Proj4js.Point(this.x,this.y,this.z);},toString:function(){return("x="+this.x+",y="+this.y);},toShortString:function(){return(this.x+", "+this.y);}});Proj4js.PrimeMeridian={"greenwich":0.0,"lisbon":-9.131906111111,"paris":2.337229166667,"bogota":-74.
 080916666667,"madrid":-3.687938888889,"rome":12.452333333333,"bern":7.439583333333,"jakarta":106.807719444444,"ferro":-17.666666666667,"brussels":4.367975,"stockholm":18.058277777778,"athens":23.7163375,"oslo":10.722916666667};Proj4js.Ellipsoid={"MERIT":{a:6378137.0,rf:298.257,ellipseName:"MERIT 1983"},"SGS85":{a:6378136.0,rf:298.257,ellipseName:"Soviet Geodetic System 85"},"GRS80":{a:6378137.0,rf:298.257222101,ellipseName:"GRS 1980(IUGG, 1980)"},"IAU76":{a:6378140.0,rf:298.257,ellipseName:"IAU 1976"},"airy":{a:6377563.396,b:6356256.910,ellipseName:"Airy 1830"},"APL4.":{a:6378137,rf:298.25,ellipseName:"Appl. Physics. 1965"},"NWL9D":{a:6378145.0,rf:298.25,ellipseName:"Naval Weapons Lab., 1965"},"mod_airy":{a:6377340.189,b:6356034.446,ellipseName:"Modified Airy"},"andrae":{a:6377104.43,rf:300.0,ellipseName:"Andrae 1876 (Den., Iclnd.)"},"aust_SA":{a:6378160.0,rf:298.25,ellipseName:"Australian Natl & S. Amer. 1969"},"GRS67":{a:6378160.0,rf:298.2471674270,ellipseName:"GRS 67(IUGG
  1967)"},"bessel":{a:6377397.155,rf:299.1528128,ellipseName:"Bessel 1841"},"bess_nam":{a:6377483.865,rf:299.1528128,ellipseName:"Bessel 1841 (Namibia)"},"clrk66":{a:6378206.4,b:6356583.8,ellipseName:"Clarke 1866"},"clrk80":{a:6378249.145,rf:293.4663,ellipseName:"Clarke 1880 mod."},"CPM":{a:6375738.7,rf:334.29,ellipseName:"Comm. des Poids et Mesures 1799"},"delmbr":{a:6376428.0,rf:311.5,ellipseName:"Delambre 1810 (Belgium)"},"engelis":{a:6378136.05,rf:298.2566,ellipseName:"Engelis 1985"},"evrst30":{a:6377276.345,rf:300.8017,ellipseName:"Everest 1830"},"evrst48":{a:6377304.063,rf:300.8017,ellipseName:"Everest 1948"},"evrst56":{a:6377301.243,rf:300.8017,ellipseName:"Everest 1956"},"evrst69":{a:6377295.664,rf:300.8017,ellipseName:"Everest 1969"},"evrstSS":{a:6377298.556,rf:300.8017,ellipseName:"Everest (Sabah & Sarawak)"},"fschr60":{a:6378166.0,rf:298.3,ellipseName:"Fischer (Mercury Datum) 1960"},"fschr60m":{a:6378155.0,rf:298.3,ellipseName:"Fischer 1960"},"fschr68":{a:6378150.0
 ,rf:298.3,ellipseName:"Fischer 1968"},"helmert":{a:6378200.0,rf:298.3,ellipseName:"Helmert 1906"},"hough":{a:6378270.0,rf:297.0,ellipseName:"Hough"},"intl":{a:6378388.0,rf:297.0,ellipseName:"International 1909 (Hayford)"},"kaula":{a:6378163.0,rf:298.24,ellipseName:"Kaula 1961"},"lerch":{a:6378139.0,rf:298.257,ellipseName:"Lerch 1979"},"mprts":{a:6397300.0,rf:191.0,ellipseName:"Maupertius 1738"},"new_intl":{a:6378157.5,b:6356772.2,ellipseName:"New International 1967"},"plessis":{a:6376523.0,rf:6355863.0,ellipseName:"Plessis 1817 (France)"},"krass":{a:6378245.0,rf:298.3,ellipseName:"Krassovsky, 1942"},"SEasia":{a:6378155.0,b:6356773.3205,ellipseName:"Southeast Asia"},"walbeck":{a:6376896.0,b:6355834.8467,ellipseName:"Walbeck"},"WGS60":{a:6378165.0,rf:298.3,ellipseName:"WGS 60"},"WGS66":{a:6378145.0,rf:298.25,ellipseName:"WGS 66"},"WGS72":{a:6378135.0,rf:298.26,ellipseName:"WGS 72"},"WGS84":{a:6378137.0,rf:298.257223563,ellipseName:"WGS 84"},"sphere":{a:6370997.0,b:6370997.0,el
 lipseName:"Normal Sphere (r=6370997)"}};Proj4js.Datum={"WGS84":{towgs84:"0,0,0",ellipse:"WGS84",datumName:"WGS84"},"GGRS87":{towgs84:"-199.87,74.79,246.62",ellipse:"GRS80",datumName:"Greek_Geodetic_Reference_System_1987"},"NAD83":{towgs84:"0,0,0",ellipse:"GRS80",datumName:"North_American_Datum_1983"},"NAD27":{nadgrids:"@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat",ellipse:"clrk66",datumName:"North_American_Datum_1927"},"potsdam":{towgs84:"606.0,23.0,413.0",ellipse:"bessel",datumName:"Potsdam Rauenberg 1950 DHDN"},"carthage":{towgs84:"-263.0,6.0,431.0",ellipse:"clark80",datumName:"Carthage 1934 Tunisia"},"hermannskogel":{towgs84:"653.0,-212.0,449.0",ellipse:"bessel",datumName:"Hermannskogel"},"ire65":{towgs84:"482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15",ellipse:"mod_airy",datumName:"Ireland 1965"},"nzgd49":{towgs84:"59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993",ellipse:"intl",datumName:"New Zealand Geodetic Datum 1949"},"OSGB36":{towgs84:"446.448,-125.157,542.060,0.1502,0.2
 470,0.8421,-20.4894",ellipse:"airy",datumName:"Airy 1830"}};Proj4js.WGS84=new Proj4js.Proj('WGS84');Proj4js.Datum['OSB36']=Proj4js.Datum['OSGB36'];Proj4js.wktProjections={"Lambert Tangential Conformal Conic Projection":"lcc","Mercator":"merc","Transverse_Mercator":"tmerc","Transverse Mercator":"tmerc","Lambert Azimuthal Equal Area":"laea","Universal Transverse Mercator System":"utm"};Proj4js.Proj.aea={init:function(){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("aeaInitEqualLatitudes");return;}
+{var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_tmp=(p.x-Dx_BF)/M_BF;var y_tmp=(p.y-Dy_BF)/M_BF;var z_tmp=(p.z-Dz_BF)/M_BF;p.x=x_tmp+Rz_BF*y_tmp-Ry_BF*z_tmp;p.y=-Rz_BF*x_tmp+y_tmp+Rx_BF*z_tmp;p.z=Ry_BF*x_tmp-Rx_BF*y_tmp+z_tmp;}}});Proj4js.Point=Proj4js.Class({initialize:function(x,y,z){if(typeof x=='object'){this.x=x[0];this.y=x[1];this.z=x[2]||0.0;}else if(typeof x=='string'&&typeof y=='undefined'){var coords=x.split(',');this.x=parseFloat(coords[0]);this.y=parseFloat(coords[1]);this.z=parseFloat(coords[2])||0.0;}else{this.x=x;this.y=y;this.z=z||0.0;}},clone:function(){return new Proj4js.Point(this.x,this.y,this.z);},toString:function(){return("x="+this.x+",y="+this.y);},toShortString:function(){return(this.x+", "+this.y);}});Proj4js.PrimeMeridian={"greenwich":0.0,"lisbon":-9.131906111111,"paris":2.337
 229166667,"bogota":-74.080916666667,"madrid":-3.687938888889,"rome":12.452333333333,"bern":7.439583333333,"jakarta":106.807719444444,"ferro":-17.666666666667,"brussels":4.367975,"stockholm":18.058277777778,"athens":23.7163375,"oslo":10.722916666667};Proj4js.Ellipsoid={"MERIT":{a:6378137.0,rf:298.257,ellipseName:"MERIT 1983"},"SGS85":{a:6378136.0,rf:298.257,ellipseName:"Soviet Geodetic System 85"},"GRS80":{a:6378137.0,rf:298.257222101,ellipseName:"GRS 1980(IUGG, 1980)"},"IAU76":{a:6378140.0,rf:298.257,ellipseName:"IAU 1976"},"airy":{a:6377563.396,b:6356256.910,ellipseName:"Airy 1830"},"APL4.":{a:6378137,rf:298.25,ellipseName:"Appl. Physics. 1965"},"NWL9D":{a:6378145.0,rf:298.25,ellipseName:"Naval Weapons Lab., 1965"},"mod_airy":{a:6377340.189,b:6356034.446,ellipseName:"Modified Airy"},"andrae":{a:6377104.43,rf:300.0,ellipseName:"Andrae 1876 (Den., Iclnd.)"},"aust_SA":{a:6378160.0,rf:298.25,ellipseName:"Australian Natl & S. Amer. 1969"},"GRS67":{a:6378160.0,rf:298.2471674270,e
 llipseName:"GRS 67(IUGG 1967)"},"bessel":{a:6377397.155,rf:299.1528128,ellipseName:"Bessel 1841"},"bess_nam":{a:6377483.865,rf:299.1528128,ellipseName:"Bessel 1841 (Namibia)"},"clrk66":{a:6378206.4,b:6356583.8,ellipseName:"Clarke 1866"},"clrk80":{a:6378249.145,rf:293.4663,ellipseName:"Clarke 1880 mod."},"CPM":{a:6375738.7,rf:334.29,ellipseName:"Comm. des Poids et Mesures 1799"},"delmbr":{a:6376428.0,rf:311.5,ellipseName:"Delambre 1810 (Belgium)"},"engelis":{a:6378136.05,rf:298.2566,ellipseName:"Engelis 1985"},"evrst30":{a:6377276.345,rf:300.8017,ellipseName:"Everest 1830"},"evrst48":{a:6377304.063,rf:300.8017,ellipseName:"Everest 1948"},"evrst56":{a:6377301.243,rf:300.8017,ellipseName:"Everest 1956"},"evrst69":{a:6377295.664,rf:300.8017,ellipseName:"Everest 1969"},"evrstSS":{a:6377298.556,rf:300.8017,ellipseName:"Everest (Sabah & Sarawak)"},"fschr60":{a:6378166.0,rf:298.3,ellipseName:"Fischer (Mercury Datum) 1960"},"fschr60m":{a:6378155.0,rf:298.3,ellipseName:"Fischer 1960"}
 ,"fschr68":{a:6378150.0,rf:298.3,ellipseName:"Fischer 1968"},"helmert":{a:6378200.0,rf:298.3,ellipseName:"Helmert 1906"},"hough":{a:6378270.0,rf:297.0,ellipseName:"Hough"},"intl":{a:6378388.0,rf:297.0,ellipseName:"International 1909 (Hayford)"},"kaula":{a:6378163.0,rf:298.24,ellipseName:"Kaula 1961"},"lerch":{a:6378139.0,rf:298.257,ellipseName:"Lerch 1979"},"mprts":{a:6397300.0,rf:191.0,ellipseName:"Maupertius 1738"},"new_intl":{a:6378157.5,b:6356772.2,ellipseName:"New International 1967"},"plessis":{a:6376523.0,rf:6355863.0,ellipseName:"Plessis 1817 (France)"},"krass":{a:6378245.0,rf:298.3,ellipseName:"Krassovsky, 1942"},"SEasia":{a:6378155.0,b:6356773.3205,ellipseName:"Southeast Asia"},"walbeck":{a:6376896.0,b:6355834.8467,ellipseName:"Walbeck"},"WGS60":{a:6378165.0,rf:298.3,ellipseName:"WGS 60"},"WGS66":{a:6378145.0,rf:298.25,ellipseName:"WGS 66"},"WGS72":{a:6378135.0,rf:298.26,ellipseName:"WGS 72"},"WGS84":{a:6378137.0,rf:298.257223563,ellipseName:"WGS 84"},"sphere":{a:6
 370997.0,b:6370997.0,ellipseName:"Normal Sphere (r=6370997)"}};Proj4js.Datum={"WGS84":{towgs84:"0,0,0",ellipse:"WGS84",datumName:"WGS84"},"GGRS87":{towgs84:"-199.87,74.79,246.62",ellipse:"GRS80",datumName:"Greek_Geodetic_Reference_System_1987"},"NAD83":{towgs84:"0,0,0",ellipse:"GRS80",datumName:"North_American_Datum_1983"},"NAD27":{nadgrids:"@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat",ellipse:"clrk66",datumName:"North_American_Datum_1927"},"potsdam":{towgs84:"606.0,23.0,413.0",ellipse:"bessel",datumName:"Potsdam Rauenberg 1950 DHDN"},"carthage":{towgs84:"-263.0,6.0,431.0",ellipse:"clark80",datumName:"Carthage 1934 Tunisia"},"hermannskogel":{towgs84:"653.0,-212.0,449.0",ellipse:"bessel",datumName:"Hermannskogel"},"ire65":{towgs84:"482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15",ellipse:"mod_airy",datumName:"Ireland 1965"},"nzgd49":{towgs84:"59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993",ellipse:"intl",datumName:"New Zealand Geodetic Datum 1949"},"OSGB36":{towgs84:"446.448,-125
 .157,542.060,0.1502,0.2470,0.8421,-20.4894",ellipse:"airy",datumName:"Airy 1830"}};Proj4js.WGS84=new Proj4js.Proj('WGS84');Proj4js.Datum['OSB36']=Proj4js.Datum['OSGB36'];Proj4js.wktProjections={"Lambert Tangential Conformal Conic Projection":"lcc","Mercator":"merc","Popular Visualisation Pseudo Mercator":"merc","Transverse_Mercator":"tmerc","Transverse Mercator":"tmerc","Lambert Azimuthal Equal Area":"laea","Universal Transverse Mercator System":"utm"};Proj4js.Proj.aea={init:function(){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("aeaInitEqualLatitudes");return;}
 this.temp=this.b/this.a;this.es=1.0-Math.pow(this.temp,2);this.e3=Math.sqrt(this.es);this.sin_po=Math.sin(this.lat1);this.cos_po=Math.cos(this.lat1);this.t1=this.sin_po;this.con=this.sin_po;this.ms1=Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);this.qs1=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);this.sin_po=Math.sin(this.lat2);this.cos_po=Math.cos(this.lat2);this.t2=this.sin_po;this.ms2=Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);this.qs2=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);this.sin_po=Math.sin(this.lat0);this.cos_po=Math.cos(this.lat0);this.t3=this.sin_po;this.qs0=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);if(Math.abs(this.lat1-this.lat2)>Proj4js.common.EPSLN){this.ns0=(this.ms1*this.ms1-this.ms2*this.ms2)/(this.qs2-this.qs1);}else{this.ns0=this.con;}
 this.c=this.ms1*this.ms1+this.ns0*this.qs1;this.rh=this.a*Math.sqrt(this.c-this.ns0*this.qs0)/this.ns0;},forward:function(p){var lon=p.x;var lat=p.y;this.sin_phi=Math.sin(lat);this.cos_phi=Math.cos(lat);var qs=Proj4js.common.qsfnz(this.e3,this.sin_phi,this.cos_phi);var rh1=this.a*Math.sqrt(this.c-this.ns0*qs)/this.ns0;var theta=this.ns0*Proj4js.common.adjust_lon(lon-this.long0);var x=rh1*Math.sin(theta)+this.x0;var y=this.rh-rh1*Math.cos(theta)+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var rh1,qs,con,theta,lon,lat;p.x-=this.x0;p.y=this.rh-p.y+this.y0;if(this.ns0>=0){rh1=Math.sqrt(p.x*p.x+p.y*p.y);con=1.0;}else{rh1=-Math.sqrt(p.x*p.x+p.y*p.y);con=-1.0;}
 theta=0.0;if(rh1!=0.0){theta=Math.atan2(con*p.x,con*p.y);}
@@ -151,7 +168,8 @@
 if(cosc!=0.||x!=0.)lon=Math.atan2(x*sinc,cosc*rh);break;case this.OBLIQ:if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.phi0;}else{lat=Math.asin(cosc*sinph0+y*sinc*cosph0/rh);}
 c=cosc-sinph0*Math.sin(lat);if(c!=0.||x!=0.){lon=Math.atan2(x*sinc*cosph0,c*rh);}
 break;case this.N_POLE:y=-y;case this.S_POLE:if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.phi0;}else{lat=Math.asin(this.mode==this.S_POLE?-cosc:cosc);}
-lon=(x==0.&&y==0.)?0.:Math.atan2(x,y);break;}}else{rho=Math.sqrt(x*x+y*y);switch(this.mode){case this.OBLIQ:case this.EQUIT:tp=2.*Math.atan2(rho*this.cosX1,this.akm1);cosphi=Math.cos(tp);sinphi=Math.sin(tp);if(rho==0.0){phi_l=Math.asin(cosphi*this.sinX1);}else{phi_l=Math.asin(cosphi*this.sinX1+(y*sinphi*this.cosX1/rho));}
+lon=(x==0.&&y==0.)?0.:Math.atan2(x,y);break;}
+p.x=Proj4js.common.adjust_lon(lon+this.long0);p.y=lat;}else{rho=Math.sqrt(x*x+y*y);switch(this.mode){case this.OBLIQ:case this.EQUIT:tp=2.*Math.atan2(rho*this.cosX1,this.akm1);cosphi=Math.cos(tp);sinphi=Math.sin(tp);if(rho==0.0){phi_l=Math.asin(cosphi*this.sinX1);}else{phi_l=Math.asin(cosphi*this.sinX1+(y*sinphi*this.cosX1/rho));}
 tp=Math.tan(.5*(Proj4js.common.HALF_PI+phi_l));x*=sinphi;y=rho*this.cosX1*cosphi-y*this.sinX1*sinphi;pi2=Proj4js.common.HALF_PI;halfe=.5*this.e;break;case this.N_POLE:y=-y;case this.S_POLE:tp=-rho/this.akm1;phi_l=Proj4js.common.HALF_PI-2.*Math.atan(tp);pi2=-Proj4js.common.HALF_PI;halfe=-.5*this.e;break;}
 for(i=this.NITER;i--;phi_l=lat){sinphi=this.e*Math.sin(phi_l);lat=2.*Math.atan(tp*Math.pow((1.+sinphi)/(1.-sinphi),halfe))-pi2;if(Math.abs(phi_l-lat)<this.CONV){if(this.mode==this.S_POLE)lat=-lat;lon=(x==0.&&y==0.)?0.:Math.atan2(x,y);p.x=Proj4js.common.adjust_lon(lon+this.long0);p.y=lat;return p;}}}}};Proj4js.Proj.nzmg={iterations:1,init:function(){this.A=new Array();this.A[1]=+0.6399175073;this.A[2]=-0.1358797613;this.A[3]=+0.063294409;this.A[4]=-0.02526853;this.A[5]=+0.0117879;this.A[6]=-0.0055161;this.A[7]=+0.0026906;this.A[8]=-0.001333;this.A[9]=+0.00067;this.A[10]=-0.00034;this.B_re=new Array();this.B_im=new Array();this.B_re[1]=+0.7557853228;this.B_im[1]=0.0;this.B_re[2]=+0.249204646;this.B_im[2]=+0.003371507;this.B_re[3]=-0.001541739;this.B_im[3]=+0.041058560;this.B_re[4]=-0.10162907;this.B_im[4]=+0.01727609;this.B_re[5]=-0.26623489;this.B_im[5]=-0.36249218;this.B_re[6]=-0.6870983;this.B_im[6]=-1.1651967;this.C_re=new Array();this.C_im=new Array();this.C_re[1]=+1.3231
 270439;this.C_im[1]=0.0;this.C_re[2]=-0.577245789;this.C_im[2]=-0.007809598;this.C_re[3]=+0.508307513;this.C_im[3]=-0.112208952;this.C_re[4]=-0.15094762;this.C_im[4]=+0.18200602;this.C_re[5]=+1.01418179;this.C_im[5]=+1.64497696;this.C_re[6]=+1.9660549;this.C_im[6]=+2.5127645;this.D=new Array();this.D[1]=+1.5627014243;this.D[2]=+0.5185406398;this.D[3]=-0.03333098;this.D[4]=-0.1052906;this.D[5]=-0.0368594;this.D[6]=+0.007317;this.D[7]=+0.01220;this.D[8]=+0.00394;this.D[9]=-0.0013;},forward:function(p){var lon=p.x;var lat=p.y;var delta_lat=lat-this.lat0;var delta_lon=lon-this.long0;var d_phi=delta_lat/Proj4js.common.SEC_TO_RAD*1E-5;var d_lambda=delta_lon;var d_phi_n=1;var d_psi=0;for(n=1;n<=10;n++){d_phi_n=d_phi_n*d_phi;d_psi=d_psi+this.A[n]*d_phi_n;}
 var th_re=d_psi;var th_im=d_lambda;var th_n_re=1;var th_n_im=0;var th_n_re1;var th_n_im1;var z_re=0;var z_im=0;for(n=1;n<=6;n++){th_n_re1=th_n_re*th_re-th_n_im*th_im;th_n_im1=th_n_im*th_re+th_n_re*th_im;th_n_re=th_n_re1;th_n_im=th_n_im1;z_re=z_re+this.B_re[n]*th_n_re-this.B_im[n]*th_n_im;z_im=z_im+this.B_im[n]*th_n_re+this.B_re[n]*th_n_im;}
@@ -199,7 +217,7 @@
 var theta=0.0;if(rh1!=0){theta=Math.atan2((con*x),(con*y));}
 if((rh1!=0)||(this.ns>0.0)){con=1.0/this.ns;ts=Math.pow((rh1/(this.a*this.f0)),con);lat=Proj4js.common.phi2z(this.e,ts);if(lat==-9999)return null;}else{lat=-Proj4js.common.HALF_PI;}
 lon=Proj4js.common.adjust_lon(theta/this.ns+this.long0);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.laea={S_POLE:1,N_POLE:2,EQUIT:3,OBLIQ:4,init:function(){var t=Math.abs(this.lat0);if(Math.abs(t-Proj4js.common.HALF_PI)<Proj4js.common.EPSLN){this.mode=this.lat0<0.?this.S_POLE:this.N_POLE;}else if(Math.abs(t)<Proj4js.common.EPSLN){this.mode=this.EQUIT;}else{this.mode=this.OBLIQ;}
-if(this.es>0){var sinphi;this.qp=Proj4js.common.qsfnz(this.e,1.0);this.mmf=.5/(1.-this.es);this.apa=this.authset(this.es);switch(this.mode){case this.N_POLE:case this.S_POLE:this.dd=1.;break;case this.EQUIT:this.rq=Math.sqrt(.5*this.qp);this.dd=1./this.rq;this.xmf=1.;this.ymf=.5*this.qp;break;case this.OBLIQ:this.rq=Math.sqrt(.5*this.qp);sinphi=Math.sin(this.lat0);this.sinb1=Proj4js.common.qsfnz(this.e,sinphi)/this.qp;this.cosb1=Math.sqrt(1.-this.sinb1*this.sinb1);this.dd=Math.cos(this.lat0)/(Math.sqrt(1.-this.es*sinphi*sinphi)*this.rq*this.cosb1);this.ymf=(this.xmf=this.rq)/this.dd;this.xmf*=this.dd;break;}}else{if(this.mode==this.OBLIQ){this.sinph0=Math.sin(this.lat0);this.cosph0=Math.cos(this.lat0);}}},forward:function(p){var x,y;var lam=p.x;var phi=p.y;lam=Proj4js.common.adjust_lon(lam-this.long0);if(this.sphere){var coslam,cosphi,sinphi;sinphi=Math.sin(phi);cosphi=Math.cos(phi);coslam=Math.cos(lam);switch(this.mode){case this.EQUIT:y=(this.mode==this.EQUIT)?1.+cosphi*co
 slam:1.+this.sinph0*sinphi+this.cosph0*cosphi*coslam;if(y<=Proj4js.common.EPSLN){Proj4js.reportError("laea:fwd:y less than eps");return null;}
+if(this.es>0){var sinphi;this.qp=Proj4js.common.qsfnz(this.e,1.0);this.mmf=.5/(1.-this.es);this.apa=this.authset(this.es);switch(this.mode){case this.N_POLE:case this.S_POLE:this.dd=1.;break;case this.EQUIT:this.rq=Math.sqrt(.5*this.qp);this.dd=1./this.rq;this.xmf=1.;this.ymf=.5*this.qp;break;case this.OBLIQ:this.rq=Math.sqrt(.5*this.qp);sinphi=Math.sin(this.lat0);this.sinb1=Proj4js.common.qsfnz(this.e,sinphi)/this.qp;this.cosb1=Math.sqrt(1.-this.sinb1*this.sinb1);this.dd=Math.cos(this.lat0)/(Math.sqrt(1.-this.es*sinphi*sinphi)*this.rq*this.cosb1);this.ymf=(this.xmf=this.rq)/this.dd;this.xmf*=this.dd;break;}}else{if(this.mode==this.OBLIQ){this.sinph0=Math.sin(this.lat0);this.cosph0=Math.cos(this.lat0);}}},forward:function(p){var x,y;var lam=p.x;var phi=p.y;lam=Proj4js.common.adjust_lon(lam-this.long0);if(this.sphere){var coslam,cosphi,sinphi;sinphi=Math.sin(phi);cosphi=Math.cos(phi);coslam=Math.cos(lam);switch(this.mode){case this.OBLIQ:case this.EQUIT:y=(this.mode==this.EQU
 IT)?1.+cosphi*coslam:1.+this.sinph0*sinphi+this.cosph0*cosphi*coslam;if(y<=Proj4js.common.EPSLN){Proj4js.reportError("laea:fwd:y less than eps");return null;}
 y=Math.sqrt(2./y);x=y*cosphi*Math.sin(lam);y*=(this.mode==this.EQUIT)?sinphi:this.cosph0*sinphi-this.sinph0*cosphi*coslam;break;case this.N_POLE:coslam=-coslam;case this.S_POLE:if(Math.abs(phi+this.phi0)<Proj4js.common.EPSLN){Proj4js.reportError("laea:fwd:phi < eps");return null;}
 y=Proj4js.common.FORTPI-phi*.5;y=2.*((this.mode==this.S_POLE)?Math.cos(y):Math.sin(y));x=y*Math.sin(lam);y*=coslam;break;}}else{var coslam,sinlam,sinphi,q,sinb=0.0,cosb=0.0,b=0.0;coslam=Math.cos(lam);sinlam=Math.sin(lam);sinphi=Math.sin(phi);q=Proj4js.common.qsfnz(this.e,sinphi);if(this.mode==this.OBLIQ||this.mode==this.EQUIT){sinb=q/this.qp;cosb=Math.sqrt(1.-sinb*sinb);}
 switch(this.mode){case this.OBLIQ:b=1.+this.sinb1*sinb+this.cosb1*cosb*coslam;break;case this.EQUIT:b=1.+cosb*coslam;break;case this.N_POLE:b=Proj4js.common.HALF_PI+phi;q=this.qp-q;break;case this.S_POLE:b=phi-Proj4js.common.HALF_PI;q=this.qp+q;break;}
More information about the fusion-commits mailing list
