[fusion-dev] Re: [fusion-users] fusion 1.1 planning
Julien-Samuel Lacroix jlacroix at mapgears.com
Wed May 7 15:25:41 EDT 2008
Let's go that way then! :)
Did some work have already been done toward the support for other
OpenLayers types? This would probably be the first step toward the
Vector support. Is it still an idea or is there plan already?
Julien
Paul Spencer wrote:
> Hey Julien,
> there is already a CanvasTool class that provides client side vector
> capability on which you could create drawing and editing tools. I use
> the CanvasTool class as a mix-in to SelectPolygon (for instance).
> I would love to get this updated (or replaced) to use Layer.Vector and
> provide widgets for the vector editing stuff but I don't know if I  will
> have time - if you are willing to work on it, I would work with  you on it.
> Cheers
> Paul
> On 6-May-08, at 3:20 PM, Julien-Samuel Lacroix wrote:
>> > * implement support for other OpenLayers layer types through the
>> > MapGroup tag in the ApplicationDefinition
>> Hi,
>> What a coincidence! :) After demo-ing Fusion to a client last  Friday,
>> a question raised. Is it possible to use vector edition  features from
>> OpenLayers inside Fusion?
>> Currently it's not possible. From what you write here, it would be
>> possible to add OpenLayers layers on the top of a Fusion map. Could
>> we then add a Vector layer and use the vector edition controls? I
>> guess that would need a new widget for vector edition, right?
>> Can you give us more details?
>> Julien
>> Mapgears
>> http://www.mapgears.com/
>> fusion-dev mailing list
>> fusion-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
>    Paul Spencer
>    Chief Technology Officer
>    DM Solutions Group Inc
>    http://www.dmsolutions.ca/
Mapgears
More information about the fusion-dev mailing list
