[fusion-dev] Re: [fusion-users] fusion 1.1 planning
Paul Spencer pspencer at dmsolutions.ca
Wed May 7 20:19:06 EDT 2008
Mike would be better to comment, but I think he already has the code
at least partially working.
Paul
On 7-May-08, at 3:25 PM, Julien-Samuel Lacroix wrote:
> Hi,
> Let's go that way then! :)
> Did some work have already been done toward the support for other
> OpenLayers types? This would probably be the first step toward the
> Vector support. Is it still an idea or is there plan already?
> Julien
> Paul Spencer wrote:
>> Hey Julien,
>> there is already a CanvasTool class that provides client side
>> vector  capability on which you could create drawing and editing
>> tools. I use  the CanvasTool class as a mix-in to SelectPolygon
>> (for instance).
>> I would love to get this updated (or replaced) to use Layer.Vector
>> and  provide widgets for the vector editing stuff but I don't know
>> if I  will have time - if you are willing to work on it, I would
>> work with  you on it.
>> Cheers
>> Paul
>> On 6-May-08, at 3:20 PM, Julien-Samuel Lacroix wrote:
>>> > * implement support for other OpenLayers layer types through the
>>> > MapGroup tag in the ApplicationDefinition
>>> Hi,
>>> What a coincidence! :) After demo-ing Fusion to a client last
>>> Friday, a question raised. Is it possible to use vector edition
>>> features from OpenLayers inside Fusion?
>>> Currently it's not possible. From what you write here, it would
>>> be  possible to add OpenLayers layers on the top of a Fusion map.
>>> Could  we then add a Vector layer and use the vector edition
>>> controls? I  guess that would need a new widget for vector
>>> edition, right?
>>> Can you give us more details?
>>> Julien
>>> Mapgears
>>> http://www.mapgears.com/
>>> fusion-dev mailing list
>>> fusion-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
>>   Paul Spencer
>>   Chief Technology Officer
>>   DM Solutions Group Inc
>>   http://www.dmsolutions.ca/
> Mapgears
    Paul Spencer
More information about the fusion-dev mailing list
