[fusion-dev] Error with displaying google imagery
JP_Staff jpps975 at sbcglobal.net
Thu Oct 1 09:29:35 EDT 2009
Zak,
Thanks for the quick response. I went ahead and got the latest version from
the svn trunk. I copied the files over and used my same config files from
original version in the fusion directory. I was able to view the google
imagery but no other layers. Toolbar is blacked out along with the legend.
Now when I load the application the mapviewer is throwing an exception for
the XMLHttpRequest Object is undefined. THis leads me to point toward the
json /ajax side of things. If I run the same map from mapguide studio I end
up with a configLoadError. I checked and make sure there were no issues with
the Mime Types in IIS, but they are configured correctly. Before I revert I
was wondering if there is a possible configuration setting in a file(ie.
path from mapguideopensource to mapguide2010) I am missing since I am using
the Autodesk supported version of fusion and the one I just copied is the
MGOS version.
THanks Again,
Jean-Paul
Zak James-2 wrote:
> JP,
> Are you sure you have replaced the fusion folder installed by mapguide
> 2010 with a fresh svn version of fusin trunk?
> Zak
> -----Original Message-----
> From: JP_Staff
> Sent:  30/09/2009 17:09:56
> Subject:  [fusion-dev] Error with displaying google imagery
> Hi All,
> I am a newbie to this site, and so far have gained alot of great
> information. I am running into an issue when loading google maps in my
> current fusion template. I am currently using MG2010, and using the
> slate.html template. I am loading all layers dynamically to the map using
> MaestroAPI.I have followed the implementation of the
> http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
> for overlaying google imagery into my current map. I have modified my
> index.html file to include the google javascript file reference and I am
> currently using the fusion.js file. I have updated my current map
> definition
> to include the google reference here is a snippit of my map def
>         -95.854896545410156
>         34.845642892061733
>         10000000
> 			 Google
>               google
>                   G_HYBRID_MAP
>         MapGuide
>         true
> 					   false
> 					   true
> 					   EPSG:900913
>           {0}
> When loading the map I recieve the following javascript error
> (1) this.mapWidget.oMapOL is null
> (2)legend.currentRange is null
> (3)lots of Object reference set to null
> Then the layers load in the legend, the toolbar is not visible above the
> map.
> My layers load on the map, if I pan the map I am able to view the google
> base map, then it is covered by my other layers. I have found in the
> Legend.js where the issue is returning null, but I can't seem to locate
> the
> error wherethis.mapWidget.oMapOL is null, I am assuming it is in the
> openlayers.js, any help or guidance is much appreciated.
> THanks,
> Jean-Paul
> http://n2.nabble.com/Error-with-displaying-google-imagery-tp3745357p3745357.html
> Sent from the Fusion Developers mailing list archive at Nabble.com.
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
View this message in context: http://n2.nabble.com/Error-with-displaying-google-imagery-tp3745357p3749026.html
More information about the fusion-dev mailing list
