[fusion-dev] Error with displaying google imagery
Zak James zjames at dmsolutions.ca
Thu Oct 1 13:43:10 EDT 2009
JP,
I'm not sure what's wrong but I confess I haven't tried this with IIS.
There aren't any path differences that I know of - fusion from svn
should be a drop-in replacement under mapguide2010.
Are there any other error messages displayed in your javascript console?
zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
http://research.dmsolutions.ca
On 2009-10-01, at 9:29 AM, JP_Staff wrote:
> Zak,
> Thanks for the quick response. I went ahead and got the latest
> version from
> the svn trunk. I copied the files over and used my same config files
> from
> original version in the fusion directory. I was able to view the
> google
> imagery but no other layers. Toolbar is blacked out along with the
> legend.
> Now when I load the application the mapviewer is throwing an
> exception for
> the XMLHttpRequest Object is undefined. THis leads me to point
> toward the
> json /ajax side of things. If I run the same map from mapguide
> studio I end
> up with a configLoadError. I checked and make sure there were no
> issues with
> the Mime Types in IIS, but they are configured correctly. Before I
> revert I
> was wondering if there is a possible configuration setting in a file
> (ie.
> path from mapguideopensource to mapguide2010) I am missing since I
> am using
> the Autodesk supported version of fusion and the one I just copied
> is the
> MGOS version.
> THanks Again,
> Jean-Paul
> Zak James-2 wrote:
>> JP,
>> Are you sure you have replaced the fusion folder installed by
>> mapguide
>> 2010 with a fresh svn version of fusin trunk?
>> Zak
>> -----Original Message-----
>> From: JP_Staff
>> Sent:  30/09/2009 17:09:56
>> Subject:  [fusion-dev] Error with displaying google imagery
>> Hi All,
>> I am a newbie to this site, and so far have gained alot of great
>> information. I am running into an issue when loading google maps in
>> my
>> current fusion template. I am currently using MG2010, and using the
>> slate.html template. I am loading all layers dynamically to the map
>> using
>> MaestroAPI.I have followed the implementation of the
>> http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
>> for overlaying google imagery into my current map. I have modified my
>> index.html file to include the google javascript file reference and
>> I am
>> currently using the fusion.js file. I have updated my current map
>> definition
>> to include the google reference here is a snippit of my map def
>>        -95.854896545410156
>>        34.845642892061733
>>        10000000
>> 			 Google
>>              google
>>                  G_HYBRID_MAP
>>        MapGuide
>>        true
>> 					   false
>> 					   true
>> 					   EPSG:900913
>>          {0}
>> When loading the map I recieve the following javascript error
>> (1) this.mapWidget.oMapOL is null
>> (2)legend.currentRange is null
>> (3)lots of Object reference set to null
>> Then the layers load in the legend, the toolbar is not visible
>> above the
>> map.
>> My layers load on the map, if I pan the map I am able to view the
>> google
>> base map, then it is covered by my other layers. I have found in the
>> Legend.js where the issue is returning null, but I can't seem to
>> locate
>> the
>> error wherethis.mapWidget.oMapOL is null, I am assuming it is in the
>> openlayers.js, any help or guidance is much appreciated.
>> THanks,
>> Jean-Paul
>> View this message in context:
>> http://n2.nabble.com/Error-with-displaying-google-imagery-tp3745357p3745357.html
>> Sent from the Fusion Developers mailing list archive at Nabble.com.
>> fusion-dev mailing list
>> fusion-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
> View this message in context: http://n2.nabble.com/Error-with-displaying-google-imagery-tp3745357p3749026.html
More information about the fusion-dev mailing list
