[fusion-dev] Error with displaying google imagery
JP_Staff
jpps975 at sbcglobal.net
Mon Oct 5 14:38:50 EDT 2009
Zak,
I was able to get the google imagery to display with success thanks to your
help. It seems like my map projections weren't getting along with googles.
Now my next question is kinda a curve ball. In my past implementations I
have been using Weblayouts(not fusion) to display my maps to individuals
customers. The process of creating the maps were dynamic so different user
have different dataset and different layers. I was able to accomplish this
by using the Maestro API and manipulating my weblayout,map,and add layers at
runtime. My question is there any clean way to accomplish(besides modifying
the xml) this by modifying the application definition dynamically in the
Maestro API. In the past I was able to accomplish this using weblayouts by:
Uri host = new
Uri(ConfigurationSettings.AppSettings["MgFCGI_Path"].ToString());
HttpServerConnection conn = new HttpServerConnection(host,
SessionID, "en", true);
WebLayout webLayout =
conn.GetWebLayout(LayoutResourceID.ToString());
MapDefinition mapdef =
conn.GetMapDefinition(MapResourceID.ToString());
//add layers to map
foreach (MapLayerType layer in LayersToAdd)
layer.Visible = true;
layer.ExpandInLegend = true;
mapdef.Layers.Add(layer);
//mapdef.BackGroundColorAsHTML = "dbeaff";
//add our layer group collection to map definition
//create base map definition
MapDefinitionTypeBaseMapDefinition baseDef = new
MapDefinitionTypeBaseMapDefinition();
baseDef.BaseMapLayerGroup = BaseGroupCollection;
mapdef.BaseMapDefinition = baseDef;
baseDef.FiniteDisplayScale = new DoubleCollection();
baseDef.FiniteDisplayScale.Add(0);
baseDef.FiniteDisplayScale.Add(10000);
baseDef.FiniteDisplayScale.Add(100000);
baseDef.FiniteDisplayScale.Add(250000);
baseDef.FiniteDisplayScale.Add(600000);
baseDef.FiniteDisplayScale.Add(1000000);
baseDef.FiniteDisplayScale.Add(1500000);
baseDef.FiniteDisplayScale.Add(2000000);
baseDef.FiniteDisplayScale.Add(2500000);
baseDef.FiniteDisplayScale.Add(3000000);
baseDef.FiniteDisplayScale.Add(4000000);
baseDef.FiniteDisplayScale.Add(6000000);
baseDef.FiniteDisplayScale.Add(10000000);
//Save the modified map at its new temporary location
conn.SaveResource(mapdef);// , tempMapDef);
//Generate a temporary WebLayout id
string tempWebLayout = new ResourceIdentifier("MyLayout",
ResourceTypes.WebLayout, conn.SessionID);
//Update the WebLayout to point at the modified MapDefinition
webLayout.Map.ResourceId = mapdef.ResourceId;
//Save the modified layout at its new temporary location
conn.SaveResource(webLayout);
WebLayoutString = webLayout.ResourceId.ToString();
currently I am trying the following for application definiton
//get the application definition
ApplicationDefinitionType app_Type =
conn.GetApplicationDefinition(FlexibleLayoutResourceID.ToString());
//iterate through the map groups find the reourceid of the map and set it to
the modified with layers
MapGroupTypeCollection map_Coll = app_Type.MapSet;
foreach (MapGroupType mg_Type in map_Coll)
MapTypeCollection mcollection = mg_Type.Map;
foreach
(OSGeo.MapGuide.MaestroAPI.ApplicationDefinition.MapType m_type in
mcollection)
CustomContentType c_Type = m_type.Extension;
System.Xml.XmlElement[] elements = c_Type.Any;
//here is where i would set the new map resource id
to pointot the generated map with layers
//Generate a temporary application definition id
string tempWebLayout = new ResourceIdentifier("MyApplication",
ResourceTypes.ApplicationDefinition, conn.SessionID);
conn.SaveResourceAs(app_Type,app_Type.ResourceId.ToString());
Thanks,
JPS
Zak James-2 wrote:
> JP,
> I'm not sure what's wrong but I confess I haven't tried this with IIS.
> There aren't any path differences that I know of - fusion from svn
> should be a drop-in replacement under mapguide2010.
> Are there any other error messages displayed in your javascript console?
> zak
> Zak James
> Applications and Software Development
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
> http://research.dmsolutions.ca
> On 2009-10-01, at 9:29 AM, JP_Staff wrote:
>> Zak,
>> Thanks for the quick response. I went ahead and got the latest
>> version from
>> the svn trunk. I copied the files over and used my same config files
>> from
>> original version in the fusion directory. I was able to view the
>> google
>> imagery but no other layers. Toolbar is blacked out along with the
>> legend.
>> Now when I load the application the mapviewer is throwing an
>> exception for
>> the XMLHttpRequest Object is undefined. THis leads me to point
>> toward the
>> json /ajax side of things. If I run the same map from mapguide
>> studio I end
>> up with a configLoadError. I checked and make sure there were no
>> issues with
>> the Mime Types in IIS, but they are configured correctly. Before I
>> revert I
>> was wondering if there is a possible configuration setting in a file
>> (ie.
>> path from mapguideopensource to mapguide2010) I am missing since I
>> am using
>> the Autodesk supported version of fusion and the one I just copied
>> is the
>> MGOS version.
>> THanks Again,
>> Jean-Paul
>> Zak James-2 wrote:
>>> JP,
>>> Are you sure you have replaced the fusion folder installed by
>>> mapguide
>>> 2010 with a fresh svn version of fusin trunk?
>>> Zak
>>> -----Original Message-----
>>> From: JP_Staff
>>> Sent: 30/09/2009 17:09:56
>>> Subject: [fusion-dev] Error with displaying google imagery
>>> Hi All,
>>> I am a newbie to this site, and so far have gained alot of great
>>> information. I am running into an issue when loading google maps in
>>> my
>>> current fusion template. I am currently using MG2010, and using the
>>> slate.html template. I am loading all layers dynamically to the map
>>> using
>>> MaestroAPI.I have followed the implementation of the
>>> http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
>>> for overlaying google imagery into my current map. I have modified my
>>> index.html file to include the google javascript file reference and
>>> I am
>>> currently using the fusion.js file. I have updated my current map
>>> definition
>>> to include the google reference here is a snippit of my map def
>>> -95.854896545410156
>>> 34.845642892061733
>>> 10000000
>>> Google
>>> google
>>> G_HYBRID_MAP
>>> MapGuide
>>> true
>>> false
>>> true
>>> EPSG:900913
>>> {0}
>>> When loading the map I recieve the following javascript error
>>> (1) this.mapWidget.oMapOL is null
>>> (2)legend.currentRange is null
>>> (3)lots of Object reference set to null
>>> Then the layers load in the legend, the toolbar is not visible
>>> above the
>>> map.
>>> My layers load on the map, if I pan the map I am able to view the
>>> google
>>> base map, then it is covered by my other layers. I have found in the
>>> Legend.js where the issue is returning null, but I can't seem to
>>> locate
>>> the
>>> error wherethis.mapWidget.oMapOL is null, I am assuming it is in the
>>> openlayers.js, any help or guidance is much appreciated.
>>> THanks,
>>> Jean-Paul
>>> View this message in context:
>>> http://n2.nabble.com/Error-with-displaying-google-imagery-tp3745357p3745357.html
>>> Sent from the Fusion Developers mailing list archive at Nabble.com.
>>> fusion-dev mailing list
>>> fusion-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
>> http://n2.nabble.com/Error-with-displaying-google-imagery-tp3745357p3749026.html
View this message in context: http://n2.nabble.com/Error-with-displaying-google-imagery-tp3745357p3770696.html
More information about the fusion-dev
