[fusion-dev] fusion and projection support
Andreas Morf a.morf at fkl.ch
Tue Oct 6 11:24:18 EDT 2009
With rev. 1907 Mike added projection support to fusion - this screwed up my
fusion app where I use  projected coordinates (swiss grid): the oMapOL was
set to default value EPSG:4326 which was the source of malfunction.
I normally set the CRS in my MG-mapdefinition and I don't want to set it
again in fusion and additionally provide a EPSGxy.js (). Shouldn't fusion
read out CRS-def from MG-server mapdef for the actual map and use that for
client-side calculations?
IMHO 1907 looks a bit like a quick and dirty fix for mapserver concerns -
the whole matter shoud be discussed an planned from ground up (RFC?).
Greets, Andreas
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20091006/e7695a12/attachment.html
More information about the fusion-dev mailing list
